    Inch character in str file
    7 Posts 0 Posters 695 Views
      On 09/08/2011 at 15:56, xxxxxxxx wrote:
      Cinema 4D Version:   12+
      Language(s) :     C++  ;   PYTHON  ;
      In my .str file I have several entries with names for
      different cameras film properties.
      Some names by tradition use the " sign. (Inch)
      I.e. one film format is called: 1/1.8"
      However I'm not able to get it correct in my .str file such as:
      SDOF_FILM_17 "1/1.8",""";
      Any idea if this is possible to do in the .str file?
      (It's the res/string_us/description/my.str I'm talking about)
      Lennart
        On 09/08/2011 at 17:25, xxxxxxxx wrote:
        You might need to include the Unicode representation in the .str file but escape sequences should work.
        "1/1.8","""  is two strings.  I don't think you can do that.  I have never seen multiple strings associated with a single string resource description using a comma separator.  You should try it like this:
        "1/1.8""
          On 09/08/2011 at 17:44, xxxxxxxx wrote:
          Thanks Robert for checking. Didn't work thou, it
          then reports an error for the next line.
          Afaik "1/1.8"""; should work (no comma as I had before)
          the little research I've done so far.
          But the .str file itself is maybe not C++ ?
          I'm using it in a Python plug but thought the descriptions are C++ ?
          Lennart
            On 09/08/2011 at 19:21, xxxxxxxx wrote:
            " 1/1.8 " "" won't work since you've already closed the quoted string (bolded)
            The .str file is just a file used by C4D.  It is not C++.
            You will need the Unicode representation instead.  The escape character is still used but uses the numerical reference instead (copyright symbol, for instance) :
            \u00a9
            \u represents a Unicode sequence and the 4 digits are the value in hexadecimal.  \u0022 is the double quote.  So, you might need to represent the string resource like this:
            SDOF_FILM_17 "1/1.8\u0022";
              On 09/08/2011 at 19:28, xxxxxxxx wrote:
              This is a trick.
              But it appears that the way that C4D displays characters in it's GUI's. You can create the "illusion" of a double quote by using two single quotes next to each other like this:
              SDOF_FILM_17 "1/1.8 '' ";
              The forum here doesn't seem to display single quotes differently either.
              So here's the same line of code written phonetically:
              SDOF_FILM_17   (DoubleQuotes)1/1.8(singleQuote)(singleQuote)(DoubleQuote).
              I tried this in both a C++ and a Python tag plugin. And they both work fine under a Windows environment. And the next entries in the .str file also work properly.
              But since you're on a Mac. I don't know if this trick will work for you.
              *Oops- Cross posted with Robert
                On 09/08/2011 at 19:30, xxxxxxxx wrote:
                Thanks Robert! Works a treat!
                Was hunting Unicode on Wiki and didn't get it, now I do thanks to your snippet.
                Earlier example was also a typo. it should be: "1.8"";
                That actually works within Cinema itself, like userdata strings.
                (Even thou the ending ; (the semicolon) is "blue" in coffee script.
                Lennart
                  On 09/08/2011 at 19:32, xxxxxxxx wrote:
                  Oh, missed your post Scott, thanks for your input as well 🙂
                  Lennart
