    ID_MODELING_COLLAPSE_COMMAND Not Supported
    2 Posts 0 Posters 458 Views
      On 26/07/2011 at 16:58, xxxxxxxx wrote:
      As the title says the command
      _ID_MODELING_COLLAPSE_COMMAND  although listed in the python docs does not work via _SendModelingCommand().
      If some one could confirm this that would be great because from all my test it just does not work, i have no problem using the other commands listed though(Well the ones i have used anyway).
        On 27/07/2011 at 06:40, xxxxxxxx wrote:
        Hi tundras, I can confirm that. ID_MODELING_COLLAPSE_COMMAND is a standard command plugin, no tool command. This is listed by a mistake and needs to be removed. Cheers, Seb
