    Channel From Shader
    4 Posts 0 Posters 371 Views
      On 26/07/2011 at 07:16, xxxxxxxx wrote:
      Cinema 4D Version:   12
      in my plugin i am iterating in to material to get all shader.
      to do this i get the brunch info for the material to acces to shder head and get all nodes inside it.
      now i have the list of all shder in a material but i'dd like to know in witch channel are shader attached .... can i retrive this information from shader or i have to search that information manually?
      thanks in advance
      Franz
        On 29/07/2011 at 23:16, xxxxxxxx wrote:
        no one?
          On 31/07/2011 at 07:27, xxxxxxxx wrote:
          There is no automatic way. You have to go manually through the channels of an material and get the inserted shader.
          The problem is that a shader can be also inserted into any BaseList2D object (materials, shaders, tags etc.).
            On 31/07/2011 at 07:33, xxxxxxxx wrote:
            hello Matthias,
            thanks i was not considering that, you are right!
            i was wondering if there was an automatic way only because i'dd like to support plugin material and not only standard material .... but may a description recursion in to material can solve that issue.
            Franz
