    TraceGeometry, API wrong
    4 Posts 0 Posters 376 Views
      On 24/07/2011 at 09:03, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hy there,
      I tried the syntax from the R12 API:
      int TraceGeometry(Ray ray, int lhit, vector p, vector n)_<_h4_>_This is not working, there is a parameter missing. Which one ?
      I figured out, that the following call will be executed:
      id = vd->TraceGeometry(ray,10000,0, &pout, &nout);
      But it is just guessing...
      Thank you,
      maxx
        On 24/07/2011 at 09:05, xxxxxxxx wrote:
        max distance to trace would probably be the second parameter.
          On 24/07/2011 at 09:10, xxxxxxxx wrote:
          Are you getting an error?
          Yeah in c++ SDK 2nd argument is max distance.
          ~Shawn
            On 24/07/2011 at 09:44, xxxxxxxx wrote:
            Hy Shawn,
            yes, when using the given syntax of the API the message is "too few parameters". When using the guessed syntax, I get at least a 1 back, which implies something worked 😉
            I'll use that parameter as the max-distance, I'll have to check if I am able to get it working correctly like that.
            maxx
