    TraceGeometry (VolumeData)
    5 Posts 0 Posters 501 Views
      On 21/07/2011 at 04:59, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I use TraceGeometry within a ChannelShader. I want to figure out which polygon gets shaded at the moment. I thought that I could figure this out with using the VolumeDatas TraceGeometry method. But I always get the ID 1 returned, no matter which side (of a cube for example) gets shaded.
      Does TraceGeometry work correctly? Is the "Face ID" really the polygon ID?
      Maybe there is a better way of determining which polygon is currently shaded?
      Thank you,
      maxx
        On 24/07/2011 at 08:45, xxxxxxxx wrote:
        Push ...
          On 31/07/2011 at 06:26, xxxxxxxx wrote:
          Unfortunatly the shader/material part of COFFEE is rather limited. In C++ it's quite easy to retrieve the current shaded polygon index.
          Via BaseVolumeData::lhit you can access the current shaded polygon ID.
            On 31/07/2011 at 11:32, xxxxxxxx wrote:
            Thank you for the hint.
            But what is with the TraceGeometry function? Shouldn't this give me too the polygon-id?
            maxx
              On 31/07/2011 at 11:46, xxxxxxxx wrote:
              I'm not sure. It could be a bug or maybe the documentation is just wrong. I have to ask our developers.
