    Deformer, Point-Data
    6 Posts 0 Posters 704 Views
      On 19/07/2011 at 05:58, xxxxxxxx wrote:
      Hy there,
      I wondered if it is possible to read out the "deformed" values of a mesh having a deformer. I've seen that the PointOperator from XPresso is able to read out those values (ie. the deformed mesh). Is it possible in Python/COFFEE?
      Thank you,
      maxx
        On 19/07/2011 at 06:17, xxxxxxxx wrote:
        Use op.GetDeformCache()
          On 19/07/2011 at 07:31, xxxxxxxx wrote:
          Ah, nice, thanx Nux.
          maxx
            On 19/07/2011 at 08:00, xxxxxxxx wrote:
            Np,
            But I still don't know how to use this while rendering...
            What GetCache() and GetDeformCache() returns while rendering is always None..
              On 19/07/2011 at 09:39, xxxxxxxx wrote:
              Hy Nux,
              is there no way to attach something here? Would be very helpful ...
              For now, just grab the file from here (DeformCacheTest_maxx.c4d) :
              www.artonbit.com/data
              When I render this in the picture viewer, it is working (so the GetDeformCache() does return something).
              Is that what you mean?
              maxx
                On 19/07/2011 at 13:24, xxxxxxxx wrote:
                Hi maxx,
                try your scene with using this code and a GeneratorObject instead of a polygon object as origin.
                  global orig,copy
                  cache = orig.GetCache()
                  if cache:
                  cache = cache.GetDeformCache()
                  print orig.GetName(), orig.GetCache()
                  if not cache:
                  copy.SetAllPoints(cache.GetAllPoints())
                  copy.Message(c4d.MSG_UPDATE)
                Rendering an animation, the GetCache() returns the Cache during the animation.
                Rendering a single Frame, the GetCache() returns None.
                Thanks & Cheers,
                Niklas
