    snapping support?
    16 Posts 0 Posters 2.4k Views
      On 05/07/2011 at 06:57, xxxxxxxx wrote:
      Bool SnapTo(const Vector& t_p, Vector* delta)_<_h4_>_
      Calculates snapping for a point. The delta between the snapped point and the original is returned in delta. _h5_<_h5_>_rn
      > Bool
      >> TRUE if a snap delta was found, otherwise FALSE.
      > _uote>
      > ##### _ <_h5_>_eters
      >> constVector& t_p
      >>> The point to snap.
      >> Vector* delta
      >>> Assigned the found snap delta. The caller owns the pointed object.
      >>> Shouldn't this return a vector ?
      >>> Anyway, that's not hard to calculate, is it ?
      > Cheers,
        On 05/07/2011 at 07:44, xxxxxxxx wrote:
        Hy Nux,
        actually it is returning a Vector. "delta" is a pointer to a Vector. So I guess you supply an empty Vector which gets set to the newly found values (if found).
        What is that method supposed to do exactly? Can someone give me an example usage?
        maxx
          On 05/07/2011 at 08:05, xxxxxxxx wrote:
          It's used to find the nearest snapping point for an arbitrary point. It's used in plugin tools for instance to support snapping.
          The sum of the passed point and the returned delta is the snapping point.
            On 05/07/2011 at 09:55, xxxxxxxx wrote:
            Yes. Does this class exist in python, too?
              On 06/07/2011 at 00:30, xxxxxxxx wrote:
              Doesn't seem to.
              So this is used when I'm holding shift and moving an object ?
              If yes, try this:
              def snap(origin, point, grid) :
                def singlesnap( (o, p, d) ) :
                    p = p - o
                    p_d = p % d
                    if p_d < d / 2.:
                        return p - p_d + o
                        return p - p_d + o + d
                return map(singlesnap, zip(origin, point, grid))
              Niklas
                No, it's used to snap points to the world grid for instance, or basically to what you set in Cinema's snapping options.
                  On 06/07/2011 at 03:48, xxxxxxxx wrote:
                  |   o |                     |     |
                  -------      snaps   to  ?  ----- o
                  Right ? This is what the function above does. (see here)
                    |   o |                     |     |
                    Not quite, the function uses Cinema's snapping system. So it knows which snapping point is closest to the point you want snapping applied to. Have you worked with snapping in Cinema itself?
                    I'm talking about this stuff:
                      On 07/07/2011 at 23:40, xxxxxxxx wrote:
                      I take it as a "no it's not in there" :[
                        On 08/07/2011 at 02:03, xxxxxxxx wrote:
                        Sorry for the delay. Unfortunatly the snapping library is currently not avaible in Python.
                          On 08/07/2011 at 02:16, xxxxxxxx wrote:
                          Will the library be implemented in the future?
                            I am sorry but I can't make any statements about future development of CINEMA 4D.
                              On 08/07/2011 at 02:46, xxxxxxxx wrote:
                              Thank you.
                              You can't or your mustn't? 😉
