    Parameters
    16 Posts 0 Posters 1.7k Views
      On 30/06/2011 at 09:02, xxxxxxxx wrote:
      Got the datatype also from the dpdd->did[0].
      Then i have some additional questions.
      -I found the datatype, for example a vector, but i cannot find which component of this vector. There seems to be no sub?
      -Where's the min and max for that attribute (property)? (not for the datatype itself).
      -How can i find out if a long is maybe a cycle? I read something about that on this forum, but it seems to be a bug?
      -And last but not least, where's the current value of te property itself?
      Best,
        On 01/07/2011 at 09:13, xxxxxxxx wrote:
        All of this information should be in the description container.  DESC_MIN, DESC_MAX, DESC_CYCLE (list of options as strings).  To see if it is a cycle, you migh check the customgui from DESC_CUSTOMGUI and see if it is a CUSTOMGUI_CYCLE.  The value is stored directly in the container.
        Get the BaseContainer to get the value using the LONG id (using dpdd->did[0].id to resolve the DescID to a DescLevel and get at the LONG id - yeah, gotta luv C4D).  To do this you will either need to get the BaseContainer of the C4DAtom up-casted (bc = ((GeListNode* )ca)->GetDataInstance()) or get the Description and then use GetParameterI() to get the container (desc = ca->GetDescription(); bc = desc->GetParameterI(dpdd->did[0], array); )
          On 01/07/2011 at 15:29, xxxxxxxx wrote:
          Hey thanks 🙂 Now all OK except the value itself and some pain with the cycle.
          I do:
          BaseContainer *d = ((BaseList2D* )ca)->GetDataInstance();
          GePrint(RealToString(d->GetReal(dpdd->did[0].id,-1)));
          But i always get -1.
            On 01/07/2011 at 16:03, xxxxxxxx wrote:
            Have you checked the dpdd->did[0].id number against the expected id number.  It should be correct but it never hurts to verify.  As long as the object 'ca' and the description id match it should work.  I've been getting the description value out of the BaseContainer for the 'object' like that forever.  Is the value really a Real value?  If you are looking at a CYCLE description, you should use GetLong().
              On 02/07/2011 at 08:10, xxxxxxxx wrote:
              Yes, i checked. What worked though is from one of your posts, januari 8, but in the getter variant:
              GeData da;
              (BaseLists2D* )ca->GetParameter(DesID(dpdd->did[0].id), da, DESCFLAGS_GET_0);
              GePrint(RealToString(da.GetReal());
              Now the interesting thing is how to get the variable programmatically out of the GeData when i know the dtype:
              LONG dType = dpdd->did[0].dtype.
              Should i use a switch case for all known dtypes ?
                On 03/07/2011 at 05:40, xxxxxxxx wrote:
                OK i used a switch plus all variants for getters and setters.
                But there is one thing, as Columbo said 😞
                How to get the min and max for that property (not for the properties datatype)
                  On 03/07/2011 at 09:43, xxxxxxxx wrote:
                  DESC_MIN and DESC_MAX are the settings for the property instance - or at least they should be.  These are what are set in the BaseContainer when creating them dynamically in GetDDescription().  Remember that there are another set of min/max settings: DESC_MINSLIDER/DESC_MAXSLIDER.  These control the min/max of the slider control not just the value that the attribute can take.
                    On 05/07/2011 at 15:57, xxxxxxxx wrote:
                    Still have a problem to find out if an AM property is a LONG or a CYCLE.
                    Got no clue, can you spell it out?
                    And...
                    If i drag a vector prop, say a rotation vector, it seems a complete vector.
                    Altough when i click in the AM on the RRR part it lits up as a unity, while the HPB lit seperately.
                    It arrives in my drag code as a whole vector.
                    I cannot drag one vector component only?
                      On 05/07/2011 at 16:33, xxxxxxxx wrote:
                      Have you tried checking the LONG DESC_CUSTOMGUI setting to be either CUSTOMGUI_CYCLE or CUSTOMGUI_CYCLEBUTTON?  At the moment, I cannot find any other way that this might be done.
                      No, you cannot drag only a vector component as the vector is seen as a description type in itself.
                        On 06/07/2011 at 03:29, xxxxxxxx wrote:
                        Robert,
                        Years ago you mentioned a magic 'DescriptionPropertyCustomGui', could that be helpfull to gather info about AM properties, like vectors and subselections? It's in the SDK, but I cannot find much info?
                        Could you be a bit more specific about how to get to these cycle ID's ?
