    Meshsequence Exporter
    8 Posts 0 Posters 1.3k Views
      On 24/06/2011 at 01:03, xxxxxxxx wrote:
      I want to export a meshsequence of an animation. If I set the documenttime to a specific frame e.g. frame 5 and export the document, then cinema always export the mesh of frame 0.
      Here ars some code snippets:
      minFrame = 0
      maxFrame = 10
      while minFrame <= maxFrame :
        doc.SetTime(c4d.BaseTime(minFrame, fps))
      filepathSuffix = filepath + "_" + str(minFrame) + "." + suffix
        c4d.documents.SaveDocument(doc, filepathSuffix, c4d.SAVEDOCUMENTFLAGS_0, format)
      minFrame = minFrame + 1
      How can I export the mesh of the frame, the playhead is?
        On 24/06/2011 at 06:18, xxxxxxxx wrote:
        In that code you set the time to frame 0, so it's starting there.
        Set it to start at current frame and set a useful last frame as well,
        like doc maxtime or loop maxtime.
        Lennart
          On 24/06/2011 at 06:58, xxxxxxxx wrote:
          In the while-loop I increment the variable "minFrame".
          If I set the minTime and maxTime of the document, cinema exports in every loopcycle the mesh of frame 0
          Here is my code:
          while minFrame <= maxFrame :;
            doc.SetMinTime(c4d.BaseTime(minFrame, fps))
            doc.SetMaxTime(c4d.BaseTime(minFrame + 1, fps))
            On 24/06/2011 at 07:22, xxxxxxxx wrote:
            In Py docs look for "Document Caching" , last in c4d.documents.BaseDocument section.
            There's a set up for running the scene, just add your save part in it.
            Lennart
              On 27/06/2011 at 01:41, xxxxxxxx wrote:
              Hi Lennard,
              thank you for youre post.
              I insert the GeSyncMessage methode to my code, but it has no impact on the results. Cinema exports the mesh of frame 0 to all of the exported files.
              Here is the code:
              fps = float(doc.GetFps())
              minTime = doc.GetMinTime()
                minFrame = int(minTime.Get() * fps)
              maxTime = doc.GetMaxTime()
                maxFrame = int(maxTime.Get() * fps)
              doc.SetTime(minTime)
                    c4d.StatusSetBar(100 / maxFrame * minFrame)
                    c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
                c4d.StatusClear()
                c4d.EventAdd(c4d.EVENT_ANIMATE)
                On 27/06/2011 at 08:18, xxxxxxxx wrote:
                Marcel, do look at the "Document Cache" example closer and
                you'll see that you need the DrawViews for anything to happen.
                I do recommend using it as is as it works as expected.
                Add your save part in it where stated and you're all set.
                Lennart
                  On 27/06/2011 at 08:50, xxxxxxxx wrote:
                  You can see the parts put into it here,
                  saving the selected object to a c4d file series.
                  Look up the different functions in Py docs to see what they do.
                  The .zfill() function is from http://docs.python.org
                  Lennart
                  # Save Selected Object To FileSeries
                  from c4d import documents, storage
                  def BrowseDoc(doc,tofile) :
                      """ Pass the document you want to run the time through"""
                      ctime = doc.GetTime() #save current time
                      fps = doc.GetFps()
                      start = doc.GetMinTime().GetFrame(fps) #set min time
                      until = doc.GetMaxTime().GetFrame(fps)
                      for f in xrange(start, until) :
                          c4d.StatusSetBar(100*(f-start)/(until-start))
                          doc.SetTime(c4d.BaseTime(f, fps))
                          c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK)
                          # do your caching here. 'f' is the current frame
                          objdoc = documents.IsolateObjects(doc,[doc.GetActiveObject()])
                          tofile = tofile+'_'+str(f).zfill(5)+'.c4d'
                          c4d.documents.SaveDocument(objdoc,tofile,c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST,c4d.FORMAT_C4DEXPORT)
                          c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED) #update timeline
                      doc.SetTime(ctime) #set time back
                      c4d.StatusClear()
                      if doc.GetActiveObject() is None:# Single Object not selected
                          return False
                      tofile = c4d.storage.SaveDialog(c4d.FILESELECTTYPE_ANYTHING)
                      if tofile:
                    On 29/06/2011 at 00:28, xxxxxxxx wrote:
                    Hi Lennart,
                    it works. Thank you so much.
