    Mograph Cloner and Python
    16 Posts 0 Posters 3.0k Views
      On 23/06/2011 at 12:39, xxxxxxxx wrote:
      thanks! so there is no name for the cloner other than it's ID#? i actually got the ID through the script log by simply creating a cloner, but i wasn't sure that it was invoking the cloner or a function to create a cloner. anyway, ill keep this in my notes for the future! thanks again scott!
        On 23/06/2011 at 13:26, xxxxxxxx wrote:
        I've found that sometimes the string ID's don't work.
        I'm not sure why. It might be because they haven't been set up yet.
        So while it's better to use the text based ID's. Sometimes you have no other choice but to use the numeric ID's.
          On 23/06/2011 at 16:27, xxxxxxxx wrote:
          cool, good to know!
            On 24/06/2011 at 02:27, xxxxxxxx wrote:
            @Scott: Yea,
            This is especially the Case in Coffee, but in Python There must be a stringid !
            i'll look it up when I'm at Home.
              On 24/06/2011 at 10:25, xxxxxxxx wrote:
              Nux, why MUST there ber a string id? the number ID seems to work just fine.
                On 24/06/2011 at 10:32, xxxxxxxx wrote:
                If you create a description for a TagData or ObjectData Plugin, the "NAME xxx;" Parameter defines inter alia the String id.I don't know if this is only for Python plugins, but I think this counts for every plugin.
                (And everything in C4D *is* actually just a plugin)
                  On 24/06/2011 at 11:15, xxxxxxxx wrote:
                  ok, good to know in case i find the ID# not working for some reason.
                    On 24/06/2011 at 11:30, xxxxxxxx wrote:
                    Yea, but the argument of the NAME Parameter is actually the same as the description name. I.e. ocube.res -> "NAME Ocube;"
                    //edit:
                    Ok, I have to excuse me ! I was wrong with theese statements:
                    @Scott: Yea,
                    I'm sorry.
                    And it really seem's like there is no string id for a clonerobject.
                    - Niklas
                      On 24/06/2011 at 14:46, xxxxxxxx wrote:
                      It's all good! i downloaded the coffee bible from scott's site and it has an entire list of all the objects with matching ID#s. super helpful for this kind of thing. just thought I'd throw it out there. thanks yet again scott!
                        On 24/06/2011 at 17:28, xxxxxxxx wrote:
                        Yes, there are some object IDs which are defined somewhere in the C++ API header file of the lib where the object belongs to. Therefore some of them are missing in Python because only a bunch of header files is parsed on startup.
                          On 24/06/2011 at 22:28, xxxxxxxx wrote:
                          For those missing ID's a quick way to find them is to look at your 'interface_icons.txt' file.  It's got all the string and Int Id's listed in one text file.   It's in your /resource/icon/ folder.  I keep a copy open in my project file for whatever I'm working on at the moment.
                            siiiiiiiiiick!😄
