    SplineHelp PrimSplines Segment Error
    3 Posts 0 Posters 560 Views
      On 23/06/2011 at 06:46, xxxxxxxx wrote:
      Let me know what I could miss here.
      Using SplineHelp() on a Primitive splineobject
      (like Text) only segment 0 is possible.
      Calling segment > 0 gets out of range.
      Also, still calling segment 0, going to position 1.0 (100%) the position
      jumps to next segments first position
      Regular splines (Pointobjects with several segments) work as expected.
          segment = 0 # <- If spline is a Prim only segment 0 works
          posUD = op[c4d.ID_USERDATA,1] # Userdata entry
          spline = op[c4d.ID_USERDATA,2] # Userdata linkfield
          if spline is None or spline.GetRealSpline() is None:
              #print 'No Spline'
              return False
          shspline = SplineHelp()
          rs       = spline.GetRealSpline()
          # try using rs in SplineHelp.InitSpline and "use_deformed_points" fail
          # but segments >0 works
          shspline.InitSpline(spline,c4d.Vector(0.0),None, False,True, False,True)
          pos      = shspline.GetPos(posUD , segment , True)
          shspline.FreeSpline()
          obj = op.GetObject()
          objm = obj.GetMg()
          objm.off = pos
          obj.SetMg(objm)
      Lennart
        On 25/06/2011 at 03:12, xxxxxxxx wrote:
        I can confirm that. The segment exception shouldnt be raised.
          On 25/06/2011 at 06:47, xxxxxxxx wrote:
          Thanks Sebastian for checking and on a week end no less!
          Please let us know when / if it is fixed (If possible).
          May I ask, regarding SplineHelp() vs SplineLengthData()..
          Why do we "need" both? They are a bit "same same but different".
          Is one of them to prefere when using splines?
          Lennart
