    VectorPosition on Spline?
    5 Posts 0 Posters 759 Views
      On 22/06/2011 at 02:41, xxxxxxxx wrote:
      Does any kind soul know how to get the vector position for a spline using Py?
      I have spent all night without any luck and cannot for the life of me
      manage to get it.
      In coffee I do as shown but whatever I try in Python can't get past
      the init part as I don't understand what class does what.
      var splineobject = object(); // a selected splineobject
      var realspline   = splineobject->GetRealSpline(); // the realspline
      var sldata       = new(SplineLengthData); // the data to use
          sldata->Init(realspline,0); // the init spline first segment
      var pos          = realspline->GetSplinePoint(0.5,0); // The vector position in space at 50% of segment
      Lennart
        On 22/06/2011 at 02:59, xxxxxxxx wrote:
        I don't see the difference between a SplineObject and a LineObject, but they can both be used with the c4d.utils.SplineHelp class.
        Try this:
        import  c4d
        from    c4d.utils    import SplineHelp
          if op is None:
              print "No object selected."
          if not op.CheckType(c4d.Ospline) :
              print "No splineobject. Retrieving Cache ..."
              globals()["op"]     = op.GetCache()
          if not op.CheckType(c4d.Oline) and not op.CheckType(c4d.Ospline) :
              print "Cache is not a line- or splineobject."
          shelp   = SplineHelp()
          shelp.InitSpline(op)
          _range  = 20
          _range  = float(_range)
          for i in xrange(int(_range) + 1) :
              i   = i / _range
              pos     = shelp.GetPosition(i)
              print str(i).ljust(5), ":", pos
        Niklas
          On 22/06/2011 at 03:04, xxxxxxxx wrote:
          Thanks Niklas, will look into it right away.
          (Also many thanks for the Cyclebutton example earlier,
          now I get attributes to work instead of using Userdata!)
          Lennart
            On 22/06/2011 at 04:05, xxxxxxxx wrote:
            Oh, I got it (Needed some sleep 🙂 )
            I didn't realize that I needed to import SplineLengthData from c4d.utils.
            Niklas, I think what you wonder is within SplineLengthData()
            as it gets whatever spline is thrown at it.
            Now it works the same as my coffee example.
            from c4d import utils
            from c4d.utils import SplineHelp, SplineLengthData
                obj = op.GetObject()
                rs = obj.GetRealSpline()
                if rs is False:
                    print 'No'
                    return False
                sdata = SplineLengthData()
                sdata.Init(rs,0)
                pos = rs.GetSplinePoint(0.5,0)
                sdata.Free()
                print pos
            Lennart
              On 22/06/2011 at 04:09, xxxxxxxx wrote:
              Corrected code for checking if spline object, should be "None", not False.
                  if rs is None:
                      print 'Not a Spline'
                      return False
                  sdata.Init(rs,0)
                  sdata.Free()
                  print pos
              Lennart
