    Press and hold button
    3 Posts 0 Posters 503 Views
      On 17/06/2011 at 12:40, xxxxxxxx wrote:
      Hy there,
      I just recently had to bake several simulations. I couldn't figure out any other way than using Cappucino and holding down my mouse-button for 20 minutes ... can't believe its implemented that way.
      So, is there a way in python, how I could simulate a click-and-hold ?
      Thank you,
      maxx
        On 17/06/2011 at 14:12, xxxxxxxx wrote:
        In Py docs look for "Document Caching" , last in c4d.documents.BaseDocument section.
        There's a set up for running the scene, just add a Record Command in it.
        Other than that don't use Cappucino, select the objects in the Timeline and bake from there:
        Functions->Bake Objects...
        Lennart
          On 18/06/2011 at 11:22, xxxxxxxx wrote:
          Thank you Lennart, a handy snippet.
          >>Other than that don't use Cappucino, select the objects in the Timeline and bake from there: Functions->Bake Objects...
          The hierarchy to bake is quite big, so I choosed Cappucino, as I can just select the parent and let it run.
          But holding down a button is not quite the way to go 😉
          maxx
