    adressing a TP Node's Objectfield
    11 Posts 0 Posters 692 Views
      On 01/06/2011 at 17:25, xxxxxxxx wrote:
      i think what i'm trying to do here is get at the xpresso tag first,
      then give an instruction to the node, right ?
      i think i can get at the tag using :
      var s = doc->FindObject("nullwithjustanexpressotag");
      var tag = s->GetFirstTag();
      in my twisted logic i should then be able to simply
      tag#GRAV_OBJECT = nullObj;
      but that's a no go of course.
        On 01/06/2011 at 20:52, xxxxxxxx wrote:
        I could be mistaken.
        But I don't think Coffee can access xpresso nodes.
          On 02/06/2011 at 06:56, xxxxxxxx wrote:
          mmmm.. is that so ? that's frustrating. I expected a simple series of actions like this ( creating and naming a null, then adding it to the object field of a specific xpresso node. ), to be a pretty reachable goal for a first exploration.
          i came across TTag Types (Texpresso). doesn't that allow for interaction with an xpresso tag ?
          maybe i'd learn more if i rephrase it :
          if you had to do something like this, how would you approach it ?
          i'm trying to learn from being result oriented here.
          if the task can't be done with one approach; rather then get stuck, I'm looking for alternatives to get at least some functionality. I guess I'm saying I'm also open for python suggestions.
          anybody willing to enlighten me ?
          (or am i asking for too much here ?)
          douwe
            On 02/06/2011 at 07:05, xxxxxxxx wrote:
            You can't dive into the XPresso tag with COFFEE, you can just allocate and insert one.
            But it is possible via Python.
            Take a look into the Py4D documentation under c4d.modules.graphview, which represents the XPresso "module".
            Niklas
              On 02/06/2011 at 09:20, xxxxxxxx wrote:
              ok, i see.
              that's clear.
              let's see what i can dig up.
              thx,
              d
                On 02/06/2011 at 23:55, xxxxxxxx wrote:
                Here's an example code by Scott Ayers.
                  On 03/06/2011 at 04:39, xxxxxxxx wrote:
                  yes, sir.
                  was looking at ( and being intimidated by ) that example yesterday.
                  need to take some time to experiment.
                  also, i think to populate a node's object field i may bump into needing GetOperatorContainer() & SetOperatorContainer() just like scott mentions.
                  i'll get back to this later when i finally get there.
                  interesting challenge.
                  d
                    On 03/06/2011 at 16:00, xxxxxxxx wrote:
                    just to make sure :
                    Is it correct that Coffee (still) doesn't allow to write user data ?
                    that would allow me to do something like :
                      var s = doc->FindObject("User Data");
                      nullObj = new(NullObject);
                      nullObj->SetName("TPGravityNull");
                      doc->InsertObject( nullObj, NULL, NULL )
                      s#ID_USERDATA:2 = nullObj;
                    doesn't seem to work though.
                    d
                      On 03/06/2011 at 17:13, xxxxxxxx wrote:
                      I don't think you can create new UserData entries with Coffee.
                      But you can definitely use it to put object's into a UserData link field:
                      var UDobject= doc->FindObject("Cube");//The object that has a Link type UserData on it
                      var n = AllocObject(Onull); //Create a null in memory only
                      n->SetName("TPGravityNull"); //Change it's name
                      doc->InsertObject(n, NULL,NULL);//Grab it from memory and put it in the OM
                      UDobject#ID_USERDATA:1 = n; //Put the Null in the first UD link field that's on the Cube
                        On 03/06/2011 at 18:46, xxxxxxxx wrote:
                        yes sir,
                        that does work, and can be fit in nicely.
                        good lesson learned.
                        thx,
                        d
