    Using c4d_symbols.h ID's in Py4D ?
    4 Posts 0 Posters 766 Views
      On 01/06/2011 at 10:19, xxxxxxxx wrote:
      how can I acess the ID's created from ResEdit in the c4d_symbols.h file ?
      They are not added to the c4d Module, and not loaded into the Plugins Scope.
      For example if I want to load a Ressourcefile for a Dialog.
      self.LoadDialogResource(DESCEDIT_MAIN)
      but "DESCEDIT_MAIN" isn't defined.
      Niklas
        On 01/06/2011 at 16:24, xxxxxxxx wrote:
        Please add these manually in your scope. They are not interpreted by the internal Parser.
          On 01/06/2011 at 23:24, xxxxxxxx wrote:
          That's pretty unfortunate. 😞
          But thank you very much. I could still find a convenient way to do this.
          class foo: pass
          res = foo()
          enm = [
          "DESCEDIT_ADDGROUP",
          "EDT_IDENTIFIER",
          "EDT_ID",
          "EDT_STRINGNAME",
          "EDT_PARAMETERS",
          "BTN_ADD_ELEMENT",
          "BTN_FINISH",
          "BTN_CANCEL",
          "IDC_LISTVIEW",
          "DESCEDIT_ADDELEMENT",
          "EDT_TYPE",
          "STR_HASCYCLE",
          "BTN_ADDCYCLE",
          "DESCEDIT_ADDCYCLEID",
          "EDIT_IDENTIFIER",
          "DESCEDIT_MAIN",
          "EDT_DESCNAME",
          "BTN_SAVE",
          "BTN_ADD_GROUP",
          "BTN_REMOVE",
          "DESCEDIT_EDITCYCLE",
          "BTN_CYCLE_ADD"  ]
          i   = 10000
          for k in enm:
            i += 1
            res.__dict__[k]     = i
            On 09/06/2011 at 09:51, xxxxxxxx wrote:
            See here 🙂
