    Multi-Selection button problem
    5 Posts 0 Posters 476 Views
      On 27/05/2011 at 11:41, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hi guys,
      I'm having trouble with Multi-Selection buttons returning the correct results.
      I'm trying to get a print result only when the multi-button is changed to a specific option.
      Here is my code:
      EXECUTIONRESULT MyTag::Execute(BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, EXECUTIONFLAGS flags)
        if (tag->GetData().GetBool(MYBOX)) // if the MYBOX checkbox attribute is enabled
         GePrint("CheckBox is enabled"); // This Works fine
        if (tag->GetData().GetLong(MULTIBUTTON, TWO)) // if the multi-button is set to this mode
            GePrint("Option Two Selected"); //<--- This Does not work!! It always prints.. no matter what option is selected!!
        return EXECUTIONRESULT_OK;
      Here is what's in my .res file:
      CONTAINER Tmytag
        NAME Tmytag;
        INCLUDE Texpression;
        INCLUDE Obase;
        GROUP ID_TAGPROPERTIES
        COLUMNS 1;
        BOOL MYBOX { }
          GROUP
          COLUMNS 1;
        LINK MY_LINK
        ACCEPT { Obase; }
        REFUSE { Osky; Oforeground; }
          SEPARATOR { LINE; }
          BUTTON BUTTON1 {}
          BUTTON BUTTON2 {}
          //BUTTON BUTTON2 {HIDDEN;} //Use this to hide the button if desired
          SEPARATOR { LINE; }
          REAL MYSLIDER { UNIT PERCENT; MIN 0.0; MAX 100.0; MINSLIDER 0.0; MAXSLIDER 10000.0; CUSTOMGUI REALSLIDER; }
          REAL MYNUMERIC {MIN 0.0; MAX 100.0; STEP 1;} //STEP controls the amount the values increase using the arrows
          STRING MYTEXTBOX {ANIM OFF; } //ANIM OFF hides the set key option from the user
          LONG    MULTIBUTTON
            CYCLE
                ONE;
                TWO;
      Can anyone tell me what I'm doing wrong?
        On 27/05/2011 at 12:36, xxxxxxxx wrote:
        That's not how the BaseContainer works. 🙂
        if (tag->GetData().GetLong(MULTIBUTTON) == TWO) ....
        The second argument in the BaseContainer GetXXX() methods is a default value if the container ID has not been set.
          On 27/05/2011 at 13:18, xxxxxxxx wrote:
          Thanks . 🍺
            On 23/09/2011 at 13:32, xxxxxxxx wrote:
            Hey Guys,
            I'm trying to do this with a Combo Button and a dialog now. But I can't figure out what it needs.
            Bool myDialog::Command(LONG id,const BaseContainer &msg)
              switch (id)
                case MY_BUTTON:
                  GePrint("Button Was Pressed");  //Works
                      break;
                case MY_CHECKBOX:
                      GePrint("CHKBox was Toggled");  //Works
                      break;
                case MY_COMBOBUTTON == SECOND_CHILD:
                      GePrint("Second Option Selected");//Does Not Work!
                      break;
            If I use: case MY_COMBOBUTTON it works. But of course it always returns the print method. No matter which child option I select. Which is bad.
            How do I get the child options of a ComboButton to return my print method if I only select a specific child?
              On 24/09/2011 at 09:57, xxxxxxxx wrote:
              Never mind.
              I think I've managed to figure it out... At least one way anyway.
                LONG second = msg.GetLong(BFM_ACTION_VALUE);  //Assigns an action to a variable
                switch (id)
                  case MY_BUTTON:
                        break;
                  case MY_CHECKBOX:
                        break;
                  case MY_COMBOBUTTON:
                        if(second == SECOND_CHILD) GePrint("Second Option Selected");
                        break;
              This was NOT obvious at all.
              Luckily the AsyncTest dialog plugin example in the SDK uses a Combo Button in it. And I was able to track down how it was working.
              I never would have been able to figure this out from the docs.
