    DescEdit (Descriptionfiles Editor)
    39 Posts 0 Posters 27.0k Views
      On 31/05/2011 at 08:12, xxxxxxxx wrote:
      That's cool.
      I've been wanting to explore making custom gui's. Mostly with C++. But also in Python.
      But I haven't found any examples to get me started.
      I copied your code from the video. But I'm not getting any text to show up. Just the black background.
        On 31/05/2011 at 08:45, xxxxxxxx wrote:
        Hm, send me the code and I will try to find the issue. 🙂
        PS: Do you know how to load a dialog ressource with python ? I can't get it to work, because the ID doesn't seem to be transferred into the Pluginscope.
        In coffe it would be:
        LoadDialogRessource(DESCEDIT_MAIN, 0);
        In Python:
        self.LoadDialogRessource(DESCEDIT_MAIN)
        but the DESCEDIT_MAIN variable isn't declared. Confused
          On 31/05/2011 at 09:33, xxxxxxxx wrote:
          Can I post my code here?
          That way other people can learn from it too.
          I'm afraid  I probably can't help  you out with your loader problem.
          But from the first glance. It looks like maybe you forgot to add the c4d. prefix?
              self.LoadDialogRessource(c4d.DESCEDIT_MAIN)
            On 31/05/2011 at 09:36, xxxxxxxx wrote:
            Unfortunately it's not loaded into the c4d module.
            Would also be fatal. 😉
            Yes, of course you can post it here, too.
            But I con't have the time now. Will test it tomorrow.
              On 31/05/2011 at 10:35, xxxxxxxx wrote:
              I took a look through my Coffee stuff to see if I had anything using LoadDialogResource().
              And I found one example:
              MyDialog::CreateLayout() //This creates the dialog gizmos using an external .res file
               var resources = LoadDialogResource(IDD_DIALOG_MyDialog, plugin_resources,BFH_SCALEFIT | BFV_SCALEFIT); // Loads the gizmo descriptions from a .res file
               return resources;
              "IDD_DIALOG_MyDialog"  is the name of the .res file located in my res folder.
              I don't know if that will help you with your python project or not.
              But it's the only example I have.
              Here's my custom gui code that I copied from your video:
              from c4d import gui
              def isIterateable(item) :
               try:
                item[0]
               except:
              return False
              class ListViewData:
               def __init__(self, iterateableData) :
                if not isIterateable(iterateableData) :
                  raise TypeError, "%s must be initialized with an iterateable value" %self.__class__.__name__
                self.data = iterateableData
               def GetColumn(self, index) :
                if index > len(self.data) :
                return self.data[index]
               def GetLengthOfData(self) :
              return len(self.data)
              class MyUA(gui.GeUserArea) :
                colors = {
                        "background": c4d.Vector(.2),
                        "lighter": c4d.Vector(.6),
                        "darker": c4d.Vector(.8, .4, .2),
                        "marked": c4d.Vector(.2),
                        "text": c4d.Vector(.1),
                        "markedText": c4d.Vector(.7, .5, .6),
                def __init__(self, rowheight, data, columnwidth = (100, )) :
              if not isIterateable(data) :
              self.minimumHeight = rowheight * len(data)
              self.rowheight = rowheight
              self.columnwidth = columnwidth
              self.data = data
              self.marked = 2
                def DrawMsg(self, x1, y1, x2, y2, msg) :
              #Set Background Color
              self.DrawSetPen(self.colors["background"])
              rHeight = self.rowheight
              #Draw lighter areas
              self.DrawSetPen(self.colors["lighter"])
              for i in xrange(0, len(self.data), 2) :
                if i == self.marked:
                 self.DrawSetPen(self.colors["marked"])
                 self.DrawRectangle(x1=0, y1 = rHeight*i, x2=x2, y2 = rHeight * (i+1))
              #Draw darker areas
              self.DrawSetPen(self.colors["darker"])
              #Draw self.data
              self.DrawSetPen(self.colors["text"])
              for i in xrange(len(self.data)) :
                 self.DrawSetPen(self.colors["markedText"])
              for j in xrange(self.data[i].GetLengthOfData()) :
                  if j >= len(self.columnwidth) :
                   width = self.columnwidth[-1]
                   width = self.columnwidth[j]
                  itemToDraw = str(self.data[i].GetColumn(j))
                  self.DrawText(itemToDraw, x1 = x1 + j*width, y1 = i * rHeight + int((rHeight * .1)))
              def GetMinimumHeight(self) :
                return 200, self.minimumHeight()
              def InputEven(self, msg) :
              #x = msg(c4d.BFM_INPUT_X)
                y = msg(c4d.BFM_INPUT_Y)
                self.marked = int(y/self.rowheight)
                self.ReDraw()
              class dlg(gui.GeDialog) :
                def Init(self) :
                pass
                def CreateLayout(self) :
              self.ua = MyUA(15, [ListViewData(("Name", "hello", 1002)) for i in range(20)])
              ua_id = self.AddUserArea(100000121, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
              self.AttachUserArea(self.ua, ua_id)
              d = dlg()
              d.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, 1000124, -1, -1, 400, 300)
              There are no errors.
              But I don't get any text values. It's just black.
                On 01/06/2011 at 08:35, xxxxxxxx wrote:
                First of all, please post such huge Code's on services like Pastebin.com.
                Then, take a look at your idnentation.
                GetMinimumHeight() and InputEven() are intendet a space to much.
                Also, it should be called InputEven t.
                Please use 4-space indentation. It makes the code much more cleaner and overviewable.
                Many editors support replacing automatically with a number of spaces, in Python's case it should be 4.
                In InputEvent you wanted to call the container, instead of use __getitem__ .
                y = msg(c4d.BFM_INPUT_Y) -> y = msg[c4d.BFM_INPUT_Y]
                You donÄt get any text, because the 2nd for-loop after the commend "Draw self.data" is wrong intended.
                should be
                Next, you don't see any coloured lines,because the drawing-clause is wrong intended.
                   #Draw lighter areas
                should be
                   #Draw lighter areas
                While drawing the Darker areas, you chose a wrong startingvalue within the xrange function.
                It should be 1, not 0 like when drawing the lighter areas.
                   #Draw darker areas
                  pass
                should be
                   #Draw darker areas
                for i in xrange(1, len(self.data), 2) :
                Now it should work.
                You also messed up the colors.
                  colors = {
                should be
                  colors = {
                          "darker": c4d.Vector(.2),
                          "marked": c4d.Vector(.8, .4, .2),
                The full working code is here.
                cheers
                  On 01/06/2011 at 08:59, xxxxxxxx wrote:
                  It was rather difficult to copy the code from your video. It's a long one.
                  Thanks for posting the code.
                  Now I just need to go through it and see If I can figure out how it all works.
                  Then try to do it in C++.
                    On 02/06/2011 at 01:32, xxxxxxxx wrote:
                    Np. 😉
                    A preview of the Description Editor.
                    There are still many bugs. It's just that you can see what it will look like. 🙂
                      On 02/06/2011 at 06:28, xxxxxxxx wrote:
                      I didn't want to make the whole video again, only because at the end of all an error occures because of a missing import in the DescEdit Example Object. 😂
                      But instead of that, everything worked fine. 🙂
                      Give me some feedback, please.
                      DescEdit Example - The first step to the output
                      Niklas
                        On 02/06/2011 at 12:56, xxxxxxxx wrote:
                        Hi Niklas,
                        I've had a look at the video now. It's coming along nicely. It looks as though you've finished the basic code for writing the various files in the correct format - which would be a real timesaver in itself.
                        It's still not as user-friendly as I'm sure you're intending to make it. For example, when defining the container object, why not have a drop-down list of possible includes rather than typing it in? Or, for a REAL element, you could let the user choose various options from a list, like the unit to be used.
                        But I'm sure you're working on all that, so carry on and I think a lot of us would use the final version.
                          On 04/06/2011 at 20:03, xxxxxxxx wrote:
                          Thanks spedler !
                          I first want to make it wokr in generall. Fine things can be added later. 🙂
                          The GUI now has been finished! After rewriting the whole ...
                          Here's the latest preview! (With me speaking, don't laugh about my englisch 😂 )
                          DescEdit Preview
                          I now have to work over ther DescFile Generation Process once again, because it's less comfortable than I had imagined.
                          Any Idea how i coul implement reopening of the files ?
                          I don't want to write a ressource-parser O.o
                          I'm thinking about my own Project fileformat for this.
                          Niklas
                          //EDIT
                          DOOH ! I forgot to implement Groups under Groups !! :OO
                            On 05/06/2011 at 01:49, xxxxxxxx wrote:
                            Looking pretty good. I've no other comments about the GUI to add to my previous ones.
                            WRT to saving/loading your files, I think this depends on how you've structured the data you have for the resource. The resource is basically a linked list so you need some way to handle child elements, siblings, and so on. Presumably you already do this - did you subclass GeListNode or something?
                            If your data is structured like that then could you save it out as a binary file, just saving each element in turn? That would make it much easier to reload it.
                            BTW, your English is excellent. No one's going to laugh.
                            Steve
                              On 05/06/2011 at 07:05, xxxxxxxx wrote:
                              Thank you. 🙂
                              No, i didn't subclass GeListNode. (Is this possible ?)
                              I have classes for Group, Element, Cycle and CycleId
                              Group, Element and Cycle hold an list called subelements.
                              In the list can be again Groups, Elements, etc.
                              The output formatting is done recursively.
                              Do you mean a file for every element ?
                              Thanks.
                              Ehm, do ou think one would really need the ID Parameter for an Element ?
                              Maybe it's not that important to be able to define some IDs yourself.
                              Niklas
                                On 05/06/2011 at 08:02, xxxxxxxx wrote:
                                I forgot you're writing in Python. In C++ it seemed to me that you could create a class based on an existing SDK class (purely for convenience - you could create your own instead) and use that to hold details of the various elements in the description. In Python you've got lists and tuples and things which make life a lot easier when managing lists of objects.
                                No, I didn't mean one file per element. I thought that you could create a file whose first parameter would hold the number of elements in the resource. Then you would save each data structure representing an element to the file, one after the other. On reloading you would just reload the required number of data structures.
                                However, to recreate the resource each element would have to point to its first child element (if any) and to its first sibling element. That's why I thought a linked list would be a handy way to manage the various elements, and since the SDK contains a class which is a linked list, you could maybe subclass that. But I don't know how it would work in Python using its built-in lists.
                                Anyway, just some thoughts.
                                  On 05/06/2011 at 10:32, xxxxxxxx wrote:
                                  Thanks for the suggestions.
                                  I came to the conclusion that it would be easier to have an own fileformat.
                                  I've completed the raw code (that I have to rewrite next time because right now it is just holy crap !).
                                  Best thing is that the chunksize is variable so the filessize won't bee tooooo large. 🙂
                                  This is the raw file text.
                                  I'm able to analyze this text. I will now implement recursive generation of the objects for the dialog. 🙂
                                  There are only a few bugs with the FileFormat formatting, i'll get them fixed too ! 😄
                                  Niklas
                                    On 18/06/2011 at 09:02, xxxxxxxx wrote:
                                    Hei Guys !
                                    I am proud to be able to tell you that Description Editor is almost finished !
                                    Here is just another Example to see it in action !
                                    (I'm sorry for my speed with the mouse . Hope you get what's going on on the screen o.o )
                                    DescEdit At the Finsihline
                                    I hope you like it ! 🙂
                                    Niklas
                                      On 18/06/2011 at 11:08, xxxxxxxx wrote:
                                      Looking interesting.  Hard to see what's what in the video due to the scale.  Any chance of some higher-res screen shots to see the various interfaces?
                                      Like your desktop, btw! 🙂
                                        On 18/06/2011 at 11:52, xxxxxxxx wrote:
                                        Are you not able to view it in Full Hd ? :0
                                        But I will make clearer and more overviewable video when it has finished. 🙂
                                        Thanks 🙂
                                        Unfortunately I didn't create the wallpaper myself. Copyright by NVidia ^^
                                        (Don't want to show off with things that are done by others)
                                          On 18/06/2011 at 12:25, xxxxxxxx wrote:
                                          Didn't expect that making it full screen would be crispy clear.  Must be the scaling down at screenr that makes the quality look blurry at the default size (non-full screen).  Much better now.
                                          What do use for your video screen capture (as I'm looking around for something on Windows 7 64-bit that works)?
                                            On 18/06/2011 at 12:37, xxxxxxxx wrote:
                                            Niklas, to me your work looks fantastic. I don't get the complete
                                            picture yet what's happening or what can be done or not.
                                            Does this mean we can make DropCycle buttons to be used in Python plugin expressions?
                                            Lennart
