    Trouble creating an xpresso node
    9 Posts 0 Posters 831 Views
      On 23/05/2011 at 16:03, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I'm trying to convert this python code to C++:
      from c4d import gui
        nm = doc.GetActiveTag().GetNodeMaster() #Get the node master of selected xpresso tag
        node = nm.CreateNode(nm.GetRoot(), c4d.ID_OPERATOR_OBJECT,insert=None, x=200, y=200) #Create the object's node
        node.AddPort(c4d.GV_PORT_OUTPUT, c4d.ID_BASEOBJECT_POSITION) #add a position output port to the object node
        print node.GetOperatorContainer()[c4d.GV_OBJECT_OBJECT_ID].GetName() #print name
      But I'm having lots of trouble figuring out how to properly use the GvNode and GvNodeMaster types:
      Bool SimplePlugin::Execute(BaseDocument *doc)
        BaseObject *obj = doc->GetFirstObject();
        if(!obj) return true;
        BaseTag *xtag = obj->MakeTag(Texpresso, NULL);
        xtag->SetBit(BIT_ACTIVE);
      ///////////// Everything is working fine up to here /////////////////
        GvNodeMaster *nm = doc->GetActiveTag()->GetNodeMaster(); //Error: BaseTag has no member GetnodeMaster
        GvNode *node = nm->CreateNode(nm->GetRoot(), ID_OPERATOR_OBJECT, insert=None, x=200, y=200); //<--wrong
        node->AddPort(GV_PORT_OUTPUT, ID_BASEOBJECT_POSITION); //<--wrong
        EventAdd();
      return true;
      Can anyone help?
        On 24/05/2011 at 02:22, xxxxxxxx wrote:
        You have to cast the BaseTag into an XPressoTag.
        Something like this:
        GvNodeMaster *nm = ((XPressoTag* )doc->GetActiveTag())->GetNodeMaster();
          On 24/05/2011 at 08:00, xxxxxxxx wrote:
          Thanks.
          Here's the code I came up with that creates an xpresso tag with a node inside of it:
          #include "c4d_graphview.h"
            GvNode *node = nm->CreateNode(nm->GetRoot(), ID_OPERATOR_OBJECT, NULL, 200, 200);
            node->AddPort(GV_PORT_OUTPUT, GV_PORT_FLAG_IS_VISIBLE);
            EventAdd();
          return true;
          However,
          I could not make this line of code work:
          node->AddPort(GV_PORT_OUTPUT, ID_BASEOBJECT_POSITION); // <---ID_BASEOBJECT_POSITION is undefined
          I assume the ID's have to be available somewhere. Because it works under python.
          But as usual. Doing a search for "ID_BASEOBJECT_POSITION" results in zilch. 😠
          And without them I can't set the ports to anything. Do you know where they are?
            On 24/05/2011 at 08:59, xxxxxxxx wrote:
            Since R12 Cinema supports Freeze transformation that's why ID_BASEOBJECT_POSITION has been renamed to ID_BASEOBJECT_REL_POSITION.
            In doubt check the IDs by dragging the description elements in question into the console or script editor.
              On 24/05/2011 at 09:43, xxxxxxxx wrote:
              When I did that. The console told me this: [OK]ID_BASEOBJECT_POSITION
              I'm not sure how that's going to help me out. Because it's not OK to use that ID in C++ .
              Maybe I'm misunderstanding how to use it?
              ID_BASEOBJECT_REL_POSITION works. But where the heck are these descriptions stored?
              I still can't find it. And I'll need the rest of them in order to create other kinds of ports.
              I also noticed that using this method. The port does not get added to my xpresso node like it does in python.
              So can I assume that this is only adding the port in memory? And it needs to somehow be inserted into the node?
              Sorry for all the questions.
              Usually python and C++ are fairly similar and I can usually figure out how to convert between the two.
              But in this case they seem to do things very differently.
                On 24/05/2011 at 11:31, xxxxxxxx wrote:
                You can find some others in the resource/res/description/obase.h|.res files.  Remember that not everything is defined in the _api folder.  A lot is defined in the modules and res folders in the resource.  Some even in the modules folder outside of the resource folder!
                  On 24/05/2011 at 11:57, xxxxxxxx wrote:
                  Thanks Robert.
                  I generally do check through all of the folders in the maxon folder. Not just in the API.
                  The problem is.. There's a ton of them. And if I looked in each and every folder it would take several hours.
                  I tried using Agent Ransack. But that doesn't seem to find them any better than windows built-in search.
                  Every time I need to look up the location of an ID. It's a painful experience.
                  If there was one thing I could change. It would be to organize the ID's in one replace, where they can easily be found with a search. Instead of scatter throughout tons of files and folders.
                  OOP is supposed to help us be organized and work faster with large projects...Not get in our way. 😉
                  Anyway.
                  I think I'm starting to see how this node ID stuff works... I think.
                  When we create an xpresso node. It has a certain type like: ID_OPERATOR_OBJECT. So to find the port ID's available to use on it. We can look up the BaseObject class and the ID's in there will probably work in that xpresso node.
                  That's my theory anyway.😉
                  Now I just need to figure out how to insert (Alloc()?)  new ports into the new xpresso node.
                    On 24/05/2011 at 12:07, xxxxxxxx wrote:
                    Agent Ransack is a great file search application.  Much more reliable than the Windows Explorer search.  That way I don't have to hunt it down, just search and destroy. 🙂
                    Here is a piece of code that Mikael Sterner gave me a few years back.  The AddPort() part seems to have worked (but cannot find the experimental project in which I was working with the Xpresso nodes) :
                        #include "c4d_operatorplugin.h"
                        #include "......\resource\modules\gv\expressiontag\res\description\gvobject.h"
                        #define GvCall(op,fnc) (((GvOperatorData* )op)->*((OPERATORPLUGIN* )C4DOS.Bl->RetrieveTableX((NodeData* )op,1))->fnc)
                        Bool MenuTest::Execute(BaseDocument *doc)
                          BaseObject* cube = doc->GetFirstObject();
                          BaseObject* sphere = cube->GetNext();
                          DescID cubeid = DescID(DescLevel(ID_BASEOBJECT_POSITION), DescLevel(VECTOR_X));
                          DescID sphereid = DescID(DescLevel(ID_BASEOBJECT_POSITION), DescLevel(VECTOR_Y));
                          XPressoTag* x = static_cast<XPressoTag*>(sphere->GetTag(Texpresso, 0));
                          if (!x) x = static_cast<XPressoTag*>(sphere->MakeTag(Texpresso, NULL));
                          GvNodeMaster* m = x->GetNodeMaster();
                          GvNode* n1 = m->CreateNode(m->GetRoot(), ID_OPERATOR_OBJECT, NULL, 8, 8);
                          n1->OperatorSetData(GV_ATOM, cube, GV_OP_DROP_IN_BODY);
                          GvOperatorData* op1 = n1->GetOperatorData();
                          LONG s1 = GvCall(op1, GetMainID)(n1, GV_PORT_OUTPUT, cubeid);
                          GvPort* p1 = n1->AddPort(GV_PORT_OUTPUT, s1, GV_PORT_FLAG_IS_VISIBLE, TRUE);
                          GvNode* n2 = m->CreateNode(m->GetRoot(), ID_OPERATOR_OBJECT, NULL, 208, 8);
                          n2->OperatorSetData(GV_ATOM, sphere, GV_OP_DROP_IN_BODY);
                          GvOperatorData* op2 = n2->GetOperatorData();
                          LONG s2 = GvCall(op2, GetMainID)(n2, GV_PORT_INPUT, sphereid);
                          GvPort* p2 = n2->AddPort(GV_PORT_INPUT, s2, GV_PORT_FLAG_IS_VISIBLE, TRUE);
                          if (p1 && p2)
                          GvNode* n1u = NULL;
                          GvNode* n2u = NULL;
                          GvPort* p1u = NULL;
                          GvPort* p2u = NULL;
                          if (m->IsConnectionValid(n1, p1, n2, p2, n1u, p1u, n2u, p2u))
                            n2->AddConnection(n1u, p1u, n2u, p2u);
                          EventAdd();
                      On 24/05/2011 at 12:57, xxxxxxxx wrote:
                      Thanks.
                      That helps me out a lot!
