    A font as a variable?
    3 Posts 0 Posters 756 Views
      On 20/05/2011 at 00:55, xxxxxxxx wrote:
      I'm having success having many pytags read custom user data from a single controller node, thanks totally to forum help, but the one variable I can't seem to get from one place to another is a font setting.
      My goal is to have a main controller node where I can set a font, and have other pytags on other nodes read and use that font selection.
      I can set up a custom user data field to be a font selection, but I'm having trouble getting the other pytags to read that selection and use that font on its affected object.
      Is there a trick to dealing with fonts? I would like to avoid just having one pytag set all the fonts in a scene, for blah blah talkie reasons I'd like to have individual pytags just act on the objects they're assigned to... if possible. Thanks -- Alex
        On 20/05/2011 at 07:12, xxxxxxxx wrote:
        Add a Font-Userdata to an Object and try the following code.
        >>> from c4d        import ID_USERDATA
        \>>> from c4d.gui    import MessageDialog        as MsgDlg
        \>>> from sys        import exc_info
        \>>> try:
                print op[ID_USERDATA, 1]
        \>>> except:
                MsgDlg(str(exc_info()))
        \>>> <type 'exceptions.AttributeError'>
            AttributeError('Parameter value not accessible (object unknown in Python)',)
            <traceback object at 0x0000000011B4FE88>
        Seem's like fontobjects are not implemented in python 😞
          On 20/05/2011 at 18:21, xxxxxxxx wrote:
          I wasn't able to try this today, but tonight or tomorrow. Again, thanks for the help!
