    BaseFile Issues
    8 Posts 0 Posters 757 Views
      On 16/05/2011 at 18:01, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:   Windows  ; Mac  ;
      I have written functions that save presets and load presets for my object plugin.  The functions use a BaseFile and loads and saves parameters.
      Here is the LoadPresets() function..
      //LOAD PRESET
      Bool PXGPlanet::LoadPreset(GeListNode* node, Filename file){
        BaseObject *op = (BaseObject* )node;
        BaseContainer *bc = op->GetDataInstance();
        //Declare the BaseFile
        AutoAlloc<BaseFile> bf;
        //Open the BaseFile for Reading.
      #ifdef C4D_R12
        bf->Open(file, FILEOPEN_READ, FILEDIALOG_IGNOREOPEN, BYTEORDER_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA);
      #else
        bf->Open(file, GE_READ, FILE_IGNOREOPEN, GE_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA);
      #endif
        //Read PXG Attributes from the File.
        //GENERAL
            //Planet Shape
            LONG pshape;
            bf->ReadLong(&pshape);
            bc->SetLong(PLANETX_GENERAL_SHAPE, pshape);
            //Radius
            LReal genrad;
            bf->ReadLReal(&genrad);
            bc->SetReal(PLANETX_GENERAL_RADIUS, genrad);
            //Segments
            LReal genseg;
            bf->ReadLReal(&genseg);
            bc->SetReal(PLANETX_GENERAL_SEGMENTS, genseg);
            //Height
            LReal genht;
            bf->ReadLReal(&genht);
            bc->SetReal(PLANETX_GENERAL_HEIGHT, genht);
            //Enable Rotation
            Bool enrot;
            bf->ReadBool(&enrot);
            bc->SetBool(PLANETX_GENERAL_ENABLE_ROTATION, enrot);
            //Rotation Direction
            LONG rotdir;
            bf->ReadLong(&rotdir);
            bc->SetLong(PLANETX_GENERAL_ROTATION_DIRECTION, rotdir);
            //Rotation Speed
            LReal rotspeed;
            bf->ReadLReal(&rotspeed);
            bc->SetReal(PLANETX_GENERAL_ROTATION_SPEED, rotspeed);
            //Frame Rate FPS
            LReal framerate;
            bf->ReadLReal(&framerate);
            bc->SetReal(PLANETX_GENERAL_SCENEFPS, framerate);
        //SURFACE
            //Surface Map
            Filename smap;
            bf->ReadFilename(&smap);
            bc->SetFilename(PLANETX_SURFACE_SURFACE_MAP, smap);
            //Enable Specular
            Bool enspec;
            bf->ReadBool(&enspec);
            bc->SetBool(PLANETX_SURFACE_SPEC_ENABLE, enspec);
            //Specular Mode
            LONG specmode;
            bf->ReadLong(&specmode);
            bc->SetLong(PLANETX_SURFACE_SPEC_MODE, specmode);
            //Specular Width
            LReal specwidth;
            bf->ReadLReal(&specwidth);
            bc->SetReal(PLANETX_SURFACE_SPEC_WIDTH, specwidth);
            //Specular Height
            LReal specheight;
            bf->ReadLReal(&specheight);
            bc->SetReal(PLANETX_SURFACE_SPEC_HEIGHT, specheight);
            //Specular Falloff
            LReal specfalloff;
            bf->ReadLReal(&specfalloff);
            bc->SetReal(PLANETX_SURFACE_SPEC_FALLOFF, specfalloff);
            //Specular Inner Width
            LReal speciwidth;
            bf->ReadLReal(&speciwidth);
            bc->SetReal(PLANETX_SURFACE_SPEC_INNER_WIDTH, speciwidth);
            //Enable Generator
            Bool engen;
            bf->ReadBool(&engen);
            bc->SetBool(PLANETX_SURFACE_ENABLE_GENERATOR, engen);
            //Sea Color
            LVector seacolor;
            bf->ReadLVector(&seacolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_SURFACE_SEA_COLOR, seacolor);
      #else
            bc->SetVector(PLANETX_SURFACE_SEA_COLOR, Vector(seacolor.x, seacolor.y, seacolor.z));
      #endif
            //Land Color
            LVector landcolor;
            bf->ReadLVector(&landcolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_SURFACE_LAND_COLOR, landcolor);
      #else
            bc->SetVector(PLANETX_SURFACE_LAND_COLOR, Vector(landcolor.x, landcolor.y, landcolor.z));
      #endif
            //Mountain Color
            LVector mtncolor;
            bf->ReadLVector(&mtncolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_SURFACE_MOUNTAIN_COLOR, mtncolor);
      #else
            bc->SetVector(PLANETX_SURFACE_MOUNTAIN_COLOR, Vector(mtncolor.x, mtncolor.y, mtncolor.z));
      #endif
            //Level
            LReal level;
            bf->ReadLReal(&level);
            bc->SetReal(PLANETX_SURFACE_LEVEL, level);
            //Frequnecy
            LReal freq;
            bf->ReadLReal(&freq);
            bc->SetReal(PLANETX_SURFACE_FREQUENCY, freq);
            //Generator Reflection
            Bool genref;
            bf->ReadBool(&genref);
            bc->SetBool(PLANETX_SURFACE_GENERATOR_USE_REFLECTION, genref);
            //Generator Elevation
            Bool genelev;
            bf->ReadBool(&genelev);
            bc->SetBool(PLANETX_SURFACE_GENERATOR_USE_ELEVATION, genelev);
            //Reflection Strength
            LReal refstr;
            bf->ReadLReal(&refstr);
            bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION_GEN, refstr);
            //Elevation Strength
            LReal elvstr;
            bf->ReadLReal(&elvstr);
            bc->SetReal(PLANETX_SURFACE_ELEVATION_STRENGTH_GEN, elvstr);
            //Use Reflection Map
            Bool usermap;
            bf->ReadBool(&usermap);
            bc->SetBool(PLANETX_SURFACE_REFLECTION_USE_MAP, usermap);
            //Reflection Map
            Filename rmap;
            bf->ReadFilename(&rmap);
            bc->SetFilename(PLANETX_SURFACE_REFLECTION_MAP, rmap);
            //Reflection Mix
            LReal refmix;
            bf->ReadLReal(&refmix);
            bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION_MMIX, refmix);
            //Surface Reflection
            LReal surfref;
            bf->ReadLReal(&surfref);
            bc->SetReal(PLANETX_SURFACE_SURFACE_REFLECTION,surfref);
            //Elevation Map
            Filename emap;
            bf->ReadFilename(&emap);
            bc->SetFilename(PLANETX_SURFACE_ELEVATION_MAP, emap);
            LReal estrength;
            bf->ReadLReal(&estrength);
            bc->SetReal(PLANETX_SURFACE_ELEVATION_STRENGTH, estrength);
            //Use Normal Map
            Bool useemap;
            bf->ReadBool(&useemap);
            bc->SetBool(PLANETX_SURFACE_USE_NORMAL_MAP, useemap);
            //Normal Map
            Filename nmap;
            bf->ReadFilename(&nmap);
            bc->SetFilename(PLANETX_SURFACE_NORMAL_MAP,nmap);
            //Normal Strength
            LReal nstrength;
            bf->ReadLReal(&nstrength);
            bc->SetReal(PLANETX_SURFACE_NORMAL_STRENGTH, nstrength);
        //CLOUDS
            //Enable Clouds
            Bool enclouds;
            bf->ReadBool(&enclouds);
            bc->SetBool(PLANETX_CLOUDS_ENABLE, enclouds);
            //Cloud Map
            Filename cmap;
            bf->ReadFilename(&cmap);
            bc->SetFilename(PLANETX_CLOUD_CLOUD_MAP,cmap);
            //Cloud Color
            LVector ccolor;
            bf->ReadLVector(&ccolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_CLOUD_COLOR, ccolor);
      #else
            bc->SetVector(PLANETX_CLOUD_COLOR, Vector(ccolor.x, ccolor.y, ccolor.z));
      #endif
            //Brightness
            LReal cbright;
            bf->ReadLReal(&cbright);
            bc->SetReal(PLANETX_CLOUD_BRIGHTNESS, cbright);
            //Thickness
            LReal cthick;
            bf->ReadLReal(&cthick);
            bc->SetReal(PLANETX_CLOUD_THICKNESS, cthick);
            //Elevation
            LReal celeva;
            bf->ReadLReal(&celeva);
            bc->SetReal(PLANETX_CLOUD_ELEVATION, celeva);
            //Enable Shadows
            Bool enshad;
            bf->ReadBool(&enshad);
            bc->SetBool(PLANETX_CLOUD_ENABLE_SHADOWS, enshad);
        //ATMOSPHERE
            //Enable Atmosphere
            Bool enatmo;
            bf->ReadBool(&enatmo);
            bc->SetBool(PLANETX_ATMOSPHERE_ENABLE, enatmo);
            //Atmosphere Color
            Gradient *atmColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_COLOR,CUSTOMDATATYPE_GRADIENT);
            Gradient *blank = Gradient::Alloc();
            LONG knotCount;
            bf->ReadLong(&knotCount);
            bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_COLOR, GeData(CUSTOMDATATYPE_GRADIENT, *blank));
            for(int i = 0; i < knotCount; i++){
                LVector color;
                LReal position;
                bf->ReadLVector(&color);
                bf->ReadLReal(&position);
                GradientKnot knot;
                Vector tmpcol = Vector(color.x, color.y, color.z);
                knot.col = tmpcol;
                knot.pos = position;
                atmColor->InsertKnot(knot);
            bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_COLOR, GeData(CUSTOMDATATYPE_GRADIENT, *atmColor));
            //Transparency Color
            Gradient *atmtColor =(Gradient* )bc->GetCustomDataType(PLANETX_ATMOSPHERE_TRANSPARENCY, CUSTOMDATATYPE_GRADIENT);
            Gradient *tblank = Gradient::Alloc();
            LONG tknotCount;
            bf->ReadLong(&tknotCount);
            bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_TRANSPARENCY, GeData(CUSTOMDATATYPE_GRADIENT, *tblank));
            for(int i = 0; i < tknotCount; i++){
                LVector tcolor;
                LReal tposition;
                bf->ReadLVector(&tcolor);
                bf->ReadLReal(&tposition);
                GradientKnot tknot;
                Vector ttmpcol = Vector(tcolor.x, tcolor.y, tcolor.z);
                tknot.col = ttmpcol;
                tknot.pos = tposition;
                atmtColor->InsertKnot(tknot);
            bc->SetParameter((DescID)(DescID)PLANETX_ATMOSPHERE_TRANSPARENCY, GeData(CUSTOMDATATYPE_GRADIENT, *atmtColor));
            //Haze Color
            LVector ahazecolor;
            bf->ReadLVector(&ahazecolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_ATMOSPHERE_HAZE_COLOR, ahazecolor);
      #else
            bc->SetVector(PLANETX_ATMOSPHERE_HAZE_COLOR, Vector(ahazecolor.x, ahazecolor.y, ahazecolor.z));
      #endif
            //Atmosphere Thickness
            LReal athick;
            bf->ReadLReal(&athick);
            bc->SetReal(PLANETX_ATMOSPHERE_THICKNESS, athick);
            //Enable Glow
            Bool eng;
            bf->ReadBool(&eng);
            bc->SetBool(PLANETX_ATMOSPHERE_ENABLE_GLOW, eng);
            //Use Material Color
            Bool emc;
            bf->ReadBool(&emc);
            bc->SetBool(PLANETX_ATMOSPHERE_GLOW_USE_COLOR, emc);
            //Glow Color
            LVector gcolor;
            bf->ReadLVector(&gcolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_ATMOSPHERE_GLOW_COLOR, gcolor);
      #else
            bc->SetVector(PLANETX_ATMOSPHERE_GLOW_COLOR, Vector(gcolor.x, gcolor.y, gcolor.z));
      #endif
            //Brightness
            LReal gbrit;
            bf->ReadLReal(&gbrit);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_BRIGHTNESS, gbrit);
            //Inner Strength
            LReal gis;
            bf->ReadLReal(&gis);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_INNERSTRENGTH, gis);
            //Outer Strength
            LReal gos;
            bf->ReadLReal(&gos);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_OUTERSTRENGTH, gos);
            //Radius
            LReal grad;
            bf->ReadLReal(&grad);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_RADIUS, grad);
            //Random
            LReal grand;
            bf->ReadLReal(&grand);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_RANDOM, grand);
            //Frequency
            LReal gfreq;
            bf->ReadLReal(&gfreq);
            bc->SetReal(PLANETX_ATMOSPHERE_GLOW_FREQUENCY, gfreq);
            //LIGHTS
            //Enable Lights
            Bool elts;
            bf->ReadBool(&elts);
            bc->SetBool(PLANETX_LIGHTS_ENABLE, elts);
            //City Lights Map
            Filename lmap;
            bf->ReadFilename(&lmap);
            bc->SetFilename(PLANETX_CITY_LIGHTS_MAP,lmap);
            //Brightness
            LReal ltsbrt;
            bf->ReadLReal(&ltsbrt);
            bc->SetReal(PLANETX_CITY_LIGHTS_BRIGHTNESS, ltsbrt);
            //Lights Color
            LVector ltscolor;
            bf->ReadLVector(&ltscolor);
      #ifdef C4D_R12
            bc->SetVector(PLANETX_CITY_LIGHTS_COLOR, ltscolor);
      #else
            bc->SetVector(PLANETX_CITY_LIGHTS_COLOR, Vector(ltscolor.x, ltscolor.y, ltscolor.z));
      #endif
      This works great when I save the file in Windows and open the file in Windows,,  The problem arises when I save the file with a PC and try to open it with a Mac.  My Mac tester tells me that the plugin loads fine but none of the preset files oad properly.  I assume that this is an issue with the ByteOrder but I do not know how to account for the different operating systems with a function like this.  Does anyone know how to allow a file that was saved on a PC via my SavePresets() function, to be opened on a Mac?
      Any help you could offer would be awesome.
      Shawn
        On 16/05/2011 at 23:55, xxxxxxxx wrote:
        As far as I know, the only area that has byteorder concern is WriteBytes and ReadBytes.  Everything else should be system independent as long as you stick with the same byte order across the board.
        I have had issues with Real, SReal, and LReal in transitioning from RXX to R12 though. In this case, it required using WriteSReal/ReadSReal to make things work.
        Considering that most contemporary Mac computers are using Intel it seems odd that there would be any issues between PC and Mac.  My suggestion is to do tests with the minimal settings being written and read and expand them until the issue appears so as to see if it is related to a certain type (esp. Reals!).  Remember that it could also be a 32-bit/64-bit issue.  Size of types varies between systems and bit width (unfortunately).  You may need to compensate for that as well.
          On 17/05/2011 at 07:35, xxxxxxxx wrote:
          How do you write the presetfiles ?
          If not with functions from C4D, then with C++ standart library methods i think ?
          As I know from Python, Windows writes some additional bytes at the start of a document, as far as I remember.
          There, you must open the file anogher way. 'wb' instead of 'w', so that no extra bytes are written.
          Maybe its the same in C++, and readinh the file on Mac makes problems because of theese additional bytes ?
          Niklas
            On 17/05/2011 at 10:22, xxxxxxxx wrote:
            I write the files the same as above but using the C4D Write...() functions instead of read..  and a few subtle differences of course
            I am not sure why it is happening.  I really need to invest in a Mac in the near future,  I don't like being in the dark on the Mac side of things.  😞
            ~Shawn
              On 17/05/2011 at 17:20, xxxxxxxx wrote:
              OMG this is so annoying..  I changed all the LReals to SReals and it still did not work..  The plugin will not load the preset file..  Here is the SavePreset() :
              //SAVE PRESET
              Bool PXGPlanet::SavePreset(GeListNode* node){
                //Set the Filename
                Filename file;
                Filename dir = GeGetPluginPath() + "presets/planets";
                file.SetDirectory(dir);
              #ifdef C4D_R12
                file.FileSelect(FILESELECTTYPE_ANYTHING, FILESELECT_SAVE, "Save Your Preset");
                //Open the BaseFile for writing.
                bf->Open(file, FILEOPEN_WRITE, FILEDIALOG_IGNOREOPEN, BYTEORDER_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA);
              #else
                file.FileSelect(FSTYPE_ANYTHING, GE_SAVE, "Save Your Preset");
                bf->Open(file, GE_WRITE, FILE_IGNOREOPEN, GE_INTEL, MACTYPE_CINEMA, MACCREATOR_CINEMA);
              #endif
                //Write PXG Attributes to the File.
                //GENERAL
                    //General Shape
                    bf->WriteLong(bc->GetLong(PLANETX_GENERAL_SHAPE));
                    //Radius
                    bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_RADIUS));
                    //Segments
                    bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_SEGMENTS));
                    //Height
                    bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_HEIGHT));
                    //Enable Rotation
                    bf->WriteBool(bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION));
                    bf->WriteLong(bc->GetLong(PLANETX_GENERAL_ROTATION_DIRECTION));
                    //Rotation Speed
                    bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_ROTATION_SPEED));
                    //Frame Rate FPS
                    bf->WriteLReal(bc->GetReal(PLANETX_GENERAL_SCENEFPS));
                //SURFACE
                    //Surface Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_SURFACE_MAP));
                    //Enable Specular
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_SPEC_ENABLE));
                    //Specular Mode
                    bf->WriteLong(bc->GetLong(PLANETX_SURFACE_SPEC_MODE));
                    //Specular Width
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_WIDTH));
                    //Specular Height
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_HEIGHT));
                    //Specular Falloff
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_FALLOFF));
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SPEC_INNER_WIDTH));
                    //Enable Generator
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_ENABLE_GENERATOR));
              #ifdef C4D_R12
                    //Sea Color
                    bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_SEA_COLOR));
                    //Land Color
                    bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_LAND_COLOR));
                    //Mountain Color
                    bf->WriteLVector(bc->GetVector(PLANETX_SURFACE_MOUNTAIN_COLOR));
              #else
                    //Helpers
                    Vector sea1 = bc->GetVector(PLANETX_SURFACE_SEA_COLOR);
                    Vector land1 = bc->GetVector(PLANETX_SURFACE_LAND_COLOR);
                    Vector mtn1 = bc->GetVector(PLANETX_SURFACE_MOUNTAIN_COLOR);
                    //Sea Color
                    bf->WriteLVector(LVector(sea1.x, sea1.y, sea1.z));
                    //Land Color
                    bf->WriteLVector(LVector(land1.x, land1.y, land1.z));
                    //Mountain Color
                    bf->WriteLVector(LVector(mtn1.x, mtn1.y, mtn1.z));
              #endif
                    //Level
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_LEVEL));
                    //Frequnecy
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_FREQUENCY));
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_GENERATOR_USE_REFLECTION));
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_GENERATOR_USE_ELEVATION));
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION_GEN));
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_ELEVATION_STRENGTH_GEN));
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_REFLECTION_USE_MAP));
                    //Reflection Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_REFLECTION_MAP));
                    //Reflection Mix
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION_MMIX));
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_SURFACE_REFLECTION));
                    //Elevation Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_ELEVATION_MAP));
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_ELEVATION_STRENGTH));
                    //Use Normal Map
                    bf->WriteBool(bc->GetBool(PLANETX_SURFACE_USE_NORMAL_MAP));
                    //Normal Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_SURFACE_NORMAL_MAP));
                    //Normal Strength
                    bf->WriteLReal(bc->GetReal(PLANETX_SURFACE_NORMAL_STRENGTH));
                //CLOUDS
                    //Enable Clouds
                    bf->WriteBool(bc->GetBool(PLANETX_CLOUDS_ENABLE));
                    //Cloud Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_CLOUD_CLOUD_MAP));
              #ifdef C4D_R12
                    //Cloud Color
                    bf->WriteLVector(bc->GetVector(PLANETX_CLOUD_COLOR));
              #else
                    //Helper
                    Vector cldclr = bc->GetVector(PLANETX_CLOUD_COLOR);
                    bf->WriteLVector(LVector(cldclr.x, cldclr.y, cldclr.z));
              #endif
                    //Brightness
                    bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_BRIGHTNESS));
                    //Thickness
                    bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_THICKNESS));
                    //Elevation
                    bf->WriteLReal(bc->GetReal(PLANETX_CLOUD_ELEVATION));
                    //Use Particles
                    bf->WriteBool(bc->GetBool(PLANETX_CLOUD_ENABLE_SHADOWS));
                //ATMOSPHERE
                    //Enable Atmosphere
                    bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_ENABLE));
                    //Atmosphere Color
                    LONG knotCount = atmColor->GetKnotCount();
                    bf->WriteLong(knotCount);
                        GradientKnot knot = atmColor->GetKnot(i);
              #ifdef C4D_R12
                        bf->WriteLVector(knot.col);
              #else
                        //Helper
                        Vector mycol = knot.col;
                        bf->WriteLVector(LVector(mycol.x, mycol.y, mycol.z));
              #endif
                        bf->WriteLReal(knot.pos);
                    LONG tknotCount = atmtColor->GetKnotCount();
                    bf->WriteLong(tknotCount);
                        GradientKnot tknot = atmtColor->GetKnot(i);
              #ifdef C4D_R12
                        bf->WriteLVector(tknot.col);
              #else
                        //Helper
                        Vector mytcol = tknot.col;
                        bf->WriteLVector(LVector(mytcol.x, mytcol.y, mytcol.z));
              #endif
                        bf->WriteLReal(tknot.pos);
              #ifdef C4D_R12
                    //Haze Color
                    bf->WriteLVector(bc->GetVector(PLANETX_ATMOSPHERE_HAZE_COLOR));
              #else
                    //Helper
                    Vector hzcol = bc->GetVector(PLANETX_ATMOSPHERE_HAZE_COLOR);
                    bf->WriteLVector(LVector(hzcol.x, hzcol.y, hzcol.z));
              #endif
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_THICKNESS));
                    //Enable Glow
                    bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_ENABLE_GLOW));
                    bf->WriteBool(bc->GetBool(PLANETX_ATMOSPHERE_GLOW_USE_COLOR));
                    //Glow Color
              #ifdef C4D_R12
                    bf->WriteLVector(bc->GetVector(PLANETX_ATMOSPHERE_GLOW_COLOR));
              #else
                    //Helper
                    Vector glcol = bc->GetVector(PLANETX_ATMOSPHERE_GLOW_COLOR);
                    bf->WriteLVector(LVector(glcol.x, glcol.y, glcol.z));
              #endif
                    //Brightness
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_BRIGHTNESS));
                    //Inner Strength
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_INNERSTRENGTH));
                    //Outer Strength
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_OUTERSTRENGTH));
                    //Radius
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_RADIUS));
                    //Random
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_RANDOM));
                    //Frequency
                    bf->WriteLReal(bc->GetReal(PLANETX_ATMOSPHERE_GLOW_FREQUENCY));
                    //LIGHTS
                    //Enable Lights
                    bf->WriteBool(bc->GetBool(PLANETX_LIGHTS_ENABLE));
                    //City Lights Map
                    bf->WriteFilename(bc->GetFilename(PLANETX_CITY_LIGHTS_MAP));
                    //Brightness
                    bf->WriteLReal(bc->GetReal(PLANETX_CITY_LIGHTS_BRIGHTNESS));
                    //Lights Color
              #ifdef C4D_R12
                    bf->WriteLVector(bc->GetVector(PLANETX_CITY_LIGHTS_COLOR));
              #else
                    //Helper
                    Vector clcol = bc->GetVector(PLANETX_CITY_LIGHTS_COLOR);
                    bf->WriteLVector(LVector(clcol.x, clcol.y, clcol.z));
              #endif
                    bc->SetString(PXG_CURRENT_PRESET_TEXT, file.GetFileString());
                    bf->Close();
                    //READ ONLY
                    if(bc->GetBool(PLANETX_GENERAL_SAVE_READONLY) == TRUE){
              #ifdef C4D_R10
                        GePrint("THIS FEATURE IS NOT AVAILABLE IN R10");
              #else
                        GeFSetAttributes(file, GE_FILE_ATTRIBUTE_READONLY, GE_FILE_ATTRIBUTE_READONLY);
                        GePrint("FILE SAVED AS READ ONLY");
              #endif
              Does anyone notice anything I botched up that would prevent it from working on a Mac?
              Man this is annoying me tonight.
              ~Shawn
                On 17/05/2011 at 23:13, xxxxxxxx wrote:
                [...] Does anyone notice anything I botched up that would prevent it from working on a Mac?Man this is annoying me tonight.Thanks,~Shawn
                Do yourself a favour and implement some basic error checking in the code and add some detailed console error messages for the customer/tester.
                Best regards,
                Wilfried
                  On 20/05/2011 at 05:48, xxxxxxxx wrote:
                  okay so after some testing, we have determined that the save preset function is saving Filenames from the attributes manager with full paths.  So for example the plugin uses external textures like test.jpg.  So the filename field gets saved as (doing this on my phone and don't havr backslash)  C:/Program Files/Maxon/Plugins/PXG Planet/Presets/Test.jpg.   So when that prset gets opened on a mac that path doesn't exist which leads to the preset not opening properly.   How can I get the preset to save the file name and location so that it can ne read by both Mac ane Windos folder structures?
                  Thanks.  Shawn
                    On 20/05/2011 at 09:54, xxxxxxxx wrote:
                    To save just the file name itself, use this:
                    Filename fn = bc->GetFilename(xxx);
                    fn = fn.GetFile();
                    As for location, that will vary from system to system (Windows, MacOS, drive or volume, etc.).  Best to use GeGetPluginPath() to prepend to the filename after reading and just store the file name (Test.jpg) in the presets file.
