    Points to plane
    6 Posts 0 Posters 600 Views
      On 12/05/2011 at 16:52, xxxxxxxx wrote:
      Cinema 4D Version:   12&11.5
      Hi all !
      I'm trying to orient an object in the same direction than a plane generated by 3 selected points ...
      I have my 3 points and their coordinates, but I can't find what I should calculate to make them a reference plane with a correctly oriented axis.
      Thanks for all suggestions...
      Mike
        On 12/05/2011 at 19:52, xxxxxxxx wrote:
        Three points are all you need to define a plane (p1, p2, p3).  Select one point as an arbitrary 'origin' (p1) and the other two become the other ends of direction vectors that also contain that point (p2-p1 and p3-p1).  So, you have to vectors which define the plane.  From there you can determine a normal on the plane (perpendicular to the planar surface) using a cross product ((p3-p1) x (p2-p1) = normal).  If you normalize all the vectors (make them to be within a length of 1.0) and orthonormalize them (make them mutually perpendicular) you will have the correctly oriented axis of the plane.
          On 13/05/2011 at 00:43, xxxxxxxx wrote:
          Ok, and then how can I orient my other object like this plane ?
          Thank you
          Mike
            On 13/05/2011 at 06:48, xxxxxxxx wrote:
            Ok now my axis is correctly placed and orientated, but it's sheared... When I do a reset system on it becomes ok.
            How can I reset it in my script ?  (I would like to avoid using CallCommand)
            Mike
              On 13/05/2011 at 07:24, xxxxxxxx wrote:
              Howdy,
              Use the cross product to square up your matrix starting with your plane's normal vector.
              So, for example if your plane's normal vector is the Y axis, then you use either:
              XAxis cross YAxis = ZAxis;
              YAxis cross ZAxis = XAxis;
              ZAxis cross XAxis = YAxis;
              or
              Adios,
              Cactus Dan
                On 13/05/2011 at 07:36, xxxxxxxx wrote:
                Thanks I'll try tonight !
                Mike
