    Tool Plugin Question
    37 Posts 0 Posters 25.6k Views
      On 10/05/2011 at 11:26, xxxxxxxx wrote:
      You might want to use GetNearestPoint() instead and check for a radial distance from there or modify your loop to exhaust the available point set, only taking those best matching your criteria.
        On 10/05/2011 at 11:37, xxxxxxxx wrote:
        LOL  oh duh.   I didn't notice that I was returning out of the loop.  Thanks for catching that.   Would GetNearestPoint() work outside of points mode?  Sorry.  I'm not home to test it. I will when I get home.
        Thanks yet again.
        Shaw
          On 10/05/2011 at 12:20, xxxxxxxx wrote:
          Thanks Robert.
          With that information I was able to change the for loop so it works with every point.
              for(int i = 0; i < pointCount; i++)
              Vector wtail = bd->SW(Vector(mouseX, mouseY, 0));
              Vector whead = bd->SW(Vector(mouseX, mouseY, 100000));
              Vector otail = (!points[i]) * wtail;
              Vector oray  = (whead - wtail) ^ (!points[i]);
              cRay->Init(objPoly, TRUE);
              cRay->Intersect(otail, !oray, 10000.0);
              Vector distance = PointLineDistance(wtail, whead, points[i]);
              const Real threshold = 20.0; // How close the mouse is to the point befor triggering the collision
              Real dist = distance.GetLength();
              if(dist <= threshold)
                  bd->DrawHandle(points[i], DRAWHANDLE_BIG, NOCLIP_Z);
                  GePrint("Collision with index#:" + RealToString(i)); // Prints the point index when collided
          Thanks for posting this example code Shawn.
          It really helps me to learn this stuff.
            On 10/05/2011 at 14:11, xxxxxxxx wrote:
            Hey glad you got it working Scott.  What function are you calling this code in?  And, does your sample draw the handle at the point that is being collided with?
            Thanks.  ~Shawn
              On 10/05/2011 at 15:01, xxxxxxxx wrote:
              I'm not calling any function with it. Other than printing the index number of the object's point array as the mouse collides with it.
              The handle code doesn't do anything. I just forgot to delete it.
                On 10/05/2011 at 15:15, xxxxxxxx wrote:
                Sorry.  I wasn't clear.  I meant in what function is this code currently?  Do you have it in your Draw() function or MouseInput().  And I meant is the handle code working on your end because it wasn't working on mine but it is now.  I am thinking that this might actually be a performance monster.  I may try Roberts recommendation of using GetNearestPoint().
                  On 10/05/2011 at 15:51, xxxxxxxx wrote:
                  I was using it in draw. So when the mouse hovered over the point it would trigger the collide.
                  But since you asked. I just tried putting it under the mouse input function.
                  And while the print still works properly when the left mouse button is clicked. The handle doesn't do anything.
                  I'm very new to this stuff. So I might not be writing it properly. Or the same way as you.
                  So here's my MouseInput code in case you're curious:
                  Bool DrawTool::MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg)
                    if (!doc) return FALSE;
                    BaseContainer state;
                    while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the left mouse button is pressed
                    if (state.GetLong(BFM_INPUT_VALUE) == 0) break; // Break out of the loop when left mouse button is NOT pressed
                    LONG x = state.GetLong(BFM_INPUT_X);
                    LONG y = state.GetLong(BFM_INPUT_Y);
                    //GePrint("Left Mouse Button is pressed");
                    BaseObject* obj = doc->GetActiveObject();
                    if(!obj) return TOOLDRAW_0;
                    PolygonObject *objPoly = (PolygonObject* )obj;
                    if (!objPoly) return TOOLDRAW_0;
                    LONG pointCount = objPoly->GetPointCount();
                    Vector *points = objPoly->GetPointW();
                    AutoAlloc<GeRayCollider> cRay;
                    GeRayColResult res;
                    // Make sure RayCollider is there
                    if (!cRay)
                        GePrint("ERROR - RayCollider not Initialized");
                        return TOOLDRAW_0;
                    On 10/05/2011 at 16:29, xxxxxxxx wrote:
                    Hmm looks like GetNearestPoint only works in Points mode
                    And as is, this GeRayCollider code runs super slow when there are a lot of points.
                    Here's what I have,  I am doing it in the draw because I want it to update live..  😉  Which I could probably do more effectively in GetCursorInfo() or write my own function and call that from the Draw() but this is mostly for testing.  🙂
                      AutoAlloc<ViewportSelect> vps;
                      if(!vps) return TOOLDRAW_0;
                      BaseObject* op = doc->GetActiveObject();
                      if(!op) return TOOLDRAW_0;
                      bd->SetMatrix_Matrix(op, Matrix());
                      ModelingCommandData mcd;
                      mcd.op = op;
                      mcd.mode = MODELINGCOMMANDMODE_ALL;
                      mcd.doc = doc;
                      SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd);
                      BaseObject *res = static_cast<BaseObject*>(mcd.result->GetIndex(0));
                      PolygonObject *objPoly = (PolygonObject * )res;
                      Vector * points = objPoly->GetPointW();
                      if (!cRay)
                          return TOOLDRAW_0;
                      for(int i = 0; i < pointCount; i++){
                          Vector wtail = bd->SW(Vector(cursorX, cursorY, 0));
                          Vector whead = bd->SW(Vector(cursorX, cursorY, 100000));
                          if(dist <= threshold){
                              bd->SetPen(Vector(1,0,0));
                      return    TOOLDRAW_AXIS|TOOLDRAW_HANDLES;
                      On 10/05/2011 at 16:41, xxxxxxxx wrote:
                      okay I moved a few things.  I took the cray->Init out of the loop so it doesn't get reinitialized each time..  that helped a lot with performance..  still working out some kinks  but I iwll post when I am done so that you have a working and optimized sample.
                      ~Shawn
                      PS if anyone has any tips for further optimizing this code, I am all ears.  LOL
                        On 10/05/2011 at 17:14, xxxxxxxx wrote:
                        SORRY- ACCIDENTAL DUPLICATE POST REMOVED!
                          On 10/05/2011 at 17:15, xxxxxxxx wrote:
                          Okay here it is all cleaned up and working.  Still a small delay with objects with a ton of points but I can't see any other way to optimize.  Any suggestions are greatly appreciated.  But here's the code for anyone who wants it.  🙂
                              mcd.op = op;
                              mcd.doc = doc;
                              Real radius        = data.GetReal(MY_RADIUS);
                              Real strength    = data.GetReal(MY_STRENGTH);
                              Real falloff    = data.GetReal(MY_FALLOFF);
                              Vector color    = data.GetVector(MY_COLOR);
                              if (!cRay)
                                  return TOOLDRAW_0;
                                  //const Real threshold = 20; //Tool Radius
                                  if(dist <= radius){
                                      bd->SetPen(color);
                            On 10/05/2011 at 18:21, xxxxxxxx wrote:
                            Could you possibly post your MouseInput function Shawn?
                            I'm getting results when hovering over the objects. But I don't know how to set up the mouse function to do anything with it.
                              On 10/05/2011 at 18:51, xxxxxxxx wrote:
                              I'm currently working on that.  I will post it when I get some results that I am happy with.  🙂
                                On 11/05/2011 at 02:59, xxxxxxxx wrote:
                                Well here is my MouseInput function.  It is still not doing what I want it to.  My goal is to be able to change Y position of the point when the user drags the mouse over the point.  Not sure why this isn't doing anything right now.   🙂
                                  if(!op) return FALSE;
                                  mcd.op = op;
                                  mcd.doc = doc;
                                  if (!objPoly) return FALSE;
                                  bd->SetMatrix_Matrix(objPoly, Matrix());
                                  if (!cRay)
                                      return FALSE;
                                  Real mx = msg.GetReal(BFM_INPUT_X);
                                  Real my = msg.GetReal(BFM_INPUT_Y);
                                  LONG button;
                                  switch (msg.GetLong(BFM_INPUT_CHANNEL))
                                    case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break;
                                    case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break;
                                    default: return TRUE;
                                  BaseContainer device;
                                  Real dx, dy;
                                  doc->AddUndo(UNDOTYPE_CHANGE, op);
                                  win->MouseDragStart(KEY_MLEFT, mx, my, MOUSEDRAGFLAGS_DONTHIDEMOUSE);
                                  while (win->MouseDrag(&dx, &dy, &device) == MOUSEDRAGRESULT_CONTINUE)
                                      if (dx == 0.0 && dy == 0.0) continue;
                                      if(dist <= radius){
                                          points[i].y += 100;
                                          objPoly->Message(MSG_UPDATE);
                                  if (win->MouseDragEnd()== MOUSEDRAGRESULT_ESCAPE)
                                      doc->DoUndo(TRUE);
                                  EventAdd();
                                What I expect to happen with this code is that when the user drags over the points, those points increase in height by 100.  But as it is, it does absolutely nothing to the points.  So I am stumped right now.  🙂
                                ~Shawn
                                  On 11/05/2011 at 09:41, xxxxxxxx wrote:
                                  Not much to make the code faster except for some smart preprocessing step to eliminate points but probably would not improve performance much (you gain some in the final loop but lose some in the preprocessing).  A small improvement would be to use pointers instead of array indices.  Also notice that you can gain more performance by referencing the point in the array once.
                                      Vector* lpoints =    points+pointCount;
                                    Vector pt;
                                    for(; points != lpoints; ++points){
                                          pt = *points;
                                        Vector otail = (!pt) * wtail;
                                        Vector oray  = (whead - wtail) ^ (!pt);
                                        Vector distance = PointLineDistance(wtail, whead, pt);
                                        if(dist <= radius){
                                            bd->SetPen(color);
                                            bd->DrawHandle(pt, DRAWHANDLE_BIG, NOCLIP_Z);
                                    On 11/05/2011 at 09:51, xxxxxxxx wrote:
                                    Thanks Robert,  I'll give that a try and see if it speeds things up.  Still can't figure out why I can't move any points...  LOL  doesn't seem to make sense, because theo bject is a polygon and I am looping through all points and attempting to move the point that is within the radius of the tool..  hmmm...
                                    Thanks again.
                                    ~Shawn
                                      On 11/05/2011 at 10:13, xxxxxxxx wrote:
                                      Howdy,
                                      Well, if I may suggest, you could find the desired point in ToolData::GetCursorInfo() and store the point index in a member LONG variable, so that when you click the mouse, and the tool enters the ToolData::MouseInput() function, the desired point has already been determined.
                                      It may be that your ToolData::MouseInput() function isn't doing anything because in the while loop you're constantly cycling through the points, checking the distance from the mouse. Once you enter the while loop, the point you want to move should already be determined.
                                      You can call the ToolData::Draw() function from the ToolData::GetCursorInfo() function by calling DrawViews(). The ToolData::Draw() function could then be as simple as getting the index from the value stored in the member LONG variable, and drawing the handle on that point.
                                      You could also store a -1 in that member LONG variable for when the mouse is not on any points, and then check the value of the index in both the ToolData::MouseInput() and ToolData::Draw() functions, and if the value is less than 0, return without doing anything.
                                      Adios,
                                      Cactus Dan
                                        On 11/05/2011 at 10:27, xxxxxxxx wrote:
                                        You most definitely may!  LOL  thanks a lot Dan I will try that out when I get home today.
                                          On 11/05/2011 at 12:11, xxxxxxxx wrote:
                                          Howdy,
                                          You're welcome. 😉
                                          A couple of other things you may want to consider in a tool that will manipulate points are:
                                          1. support for deformed points
                                          2. support for an "Only Modify Visible Elements" option
                                          Adios,
                                          Cactus Dan
                                            On 11/05/2011 at 19:22, xxxxxxxx wrote:
                                            Well..  I did the things you  mentioned Dan,  and that sped up performance immensely.  Thanks for that..  I am still trying to wrap my head around getting the points to move..  Here's some of my functions.
                                            First, two global variables are declared:
                                                  GeAutoDynamicArray<LONG>pointIndex;
                                                  LONG    rPointCount;
                                            pointIndex is an array of the point indices that are within the radius from the mouse which is determined by the user.
                                            rPointCount is the number of points that fall within that radius.
                                            Here's the GetCursorInfo() :  Here I determine the location of the mouse, figure out the points that are within the radius that is determined by the user, and store the indices of those points in the array.
                                            //GET CURSOR INFO
                                            Bool MyClass::GetCursorInfo(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, Real x, Real y, BaseContainer &bc){
                                              cursorX = x;
                                              cursorY = y;
                                              rPointCount = 0;
                                              if (x > -1.0)    SpecialEventAdd(EVMSG_UPDATEHIGHLIGHT);
                                              mcd.op = op;
                                              mcd.doc = doc;
                                              Vector wtail = bd->SW(Vector(x, y, 0));
                                              Vector whead = bd->SW(Vector(x, y, 100000));
                                              if (!cRay)
                                                  return FALSE;
                                                  if(dist <= radius){
                                                      pointIndex[rPointCount] = i;
                                                      rPointCount++;
                                            Here's the Draw() function:  Here I iterate through only the points that within the radius and draw a handle on each point to essentially highlight the points.
                                            //DRAW
                                            TOOLDRAW MyClass::Draw(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt,TOOLDRAWFLAGS flags){
                                              mcd.op = op;
                                              mcd.doc = doc;
                                              for (int i = 0; i < rPointCount; i++){
                                                  LONG tmp = pointIndex[i];
                                                  bd->SetPen(color);
                                                  bd->DrawHandle(points[tmp], DRAWHANDLE_BIG, NOCLIP_Z);
                                            Heres the MouseInput() function:  Here I convert the active object to a polygon object and then move the highlighted points.  Now I tried to do what Dan said and have the selected points already determined before I enter the while loop but I am not sure how to accomplish this,  because in order to move the correct points I still need to iterate through them..  At least I think I do.  🙂  So instead, I iterate through only the highlighted points in this MouseInput function..  but, as before, the points do not move at all..  I am sure that I am not doing something right.  Dan, am I doing it the way you envisioned?  If not, what would you change?
                                            //MOUSE INPUT
                                            Bool MyClass::MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg){
                                              mcd.op = op;
                                              mcd.doc = doc;
                                              LONG button;
                                              Real dx, dy;
                                                      points[tmp].y += 100;
                                                  doc->DoUndo(TRUE);
                                              EventAdd();
