    Tool Plugin Question
    37 Posts 0 Posters 25.6k Views
      On 09/05/2011 at 03:49, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Is it possible to affect point positions using a tool plugin without being in points mode?  for example is it possible to click on an object that I created and have the points move even though it is not made editable?  Can I access the points within that object from a tool plugin?  At one point in the process of creating my object plugin I convert it to a polygon object..  is it possible access those points with a tool?
      Shawn
      (Hopefully that makes sense. )
        On 09/05/2011 at 09:10, xxxxxxxx wrote:
        Should be possible.  First, don't disable your tool when the mode is not Point mode (let it work in object, polygon, edge, point, etc. modes).  Then you will need simply to get at the object's vertex array and change the vertices as needed.  You should be able to draw the points being affected (if you need to) using the ToolData::Draw() method.
          On 09/05/2011 at 09:32, xxxxxxxx wrote:
          I tried using GetNearestPoint() but that doesn't want to work.  Maybe I will need to use a RayCollider to get the point that is closest to the mouse?
          ~Shawn
            On 09/05/2011 at 09:59, xxxxxxxx wrote:
            I thought there was a way to map the mouseposition to global space ? I'm not sure but i think I have read about it.
              On 09/05/2011 at 11:03, xxxxxxxx wrote:
              WS() and SW() from the BaseDraw convert world to screen and screen to world spaces.
              Yes, you need to use a RayCollider to find the point nearest the cursor position (and nearest the screen plane if that is a parameter).
                On 09/05/2011 at 17:17, xxxxxxxx wrote:
                okay So I am trying this to see if I can even get a collision.  The problem is that when I run this on an object that is not editable the "pountCount" returns 0 every time.  Any idea why this would be happening?
                //Get the object
                  BaseObject *op = doc->GetActiveObject();
                  if (!op) return TOOLDRAW_0;
                  //Convert the object to a polygon
                  PolygonObject *objPoly = (PolygonObject* )op;
                  if (!objPoly) return TOOLDRAW_0;
                  LONG pointCount = objPoly->GetPointCount();
                  Vector * points = objPoly->GetPointW();
                  AutoAlloc<GeRayCollider> cRay;
                  // Make sure RayCollider is there
                  if (!cRay)
                      GePrint("ERROR - RayCollider not Initialized");
                      return TOOLDRAW_0;
                  for(int i = 0; i < pointCount; i++){
                  Vector wtail =    bd->SW(Vector(cursorX, cursorY, 0));
                  Vector whead =    bd->SW(Vector(cursorX, cursorY, 1000000));
                  Vector otail = (!points[i]) * wtail;
                  Vector oray     = (whead - wtail) ^ (!points[i]);
                  cRay->Init(objPoly, TRUE);
                  cRay->Intersect(otail, !oray, 1000000.0);
                      Vector distance = PointLineDistance(wtail, whead, points[i]);
                      const Real threshold = 200.0;
                      Real dist = distance.GetLength();
                      if(dist <= threshold)
                          bd->DrawHandle(points[i], DRAWHANDLE_BIG, NOCLIP_Z);
                          GePrint("Collision");
                          return TOOLDRAW_AXIS|TOOLDRAW_HANDLES;;
                      else
                          GePrint("No Collision");
                          return TOOLDRAW_0;
                Shawn
                  On 09/05/2011 at 21:15, xxxxxxxx wrote:
                  Not sure of the best way to go about doing this with 'procedural objects'.  My first thought would be to clone the original object (you might not need to clone first so try without and see the results), use current-state-to-object (SendModelingCommand()), and either insert into the actual document temporarily (not recommended) or into a fake doc (possibly better option).  Then apply the global matrix of the original object to the clone and use the cursor values with the RayCollider on that.  You need a PolygonObject to get polygons and vertices.  I have read that you can simply cast primitives (sphere, cube, etc.) into PolygonObject but this won't work with more complex objects such as those created with splines using SweepNURBS, for instance.
                  So, in essence, you are using a proxy object in a hidden document (do not insert into the document list!) to do the work behind the scenes.  To expedite things, create the fake document for reuse so that you don't have to constantly create/delete it as the tool is being used.
                    On 09/05/2011 at 23:25, xxxxxxxx wrote:
                    What about "isinstance()" testing for a pointobject ? Or do you want to make it editable and then apply your tool ?
                      On 10/05/2011 at 02:55, xxxxxxxx wrote:
                      Ah yes!  I forgot about current-state-to-object.  Works like a charm now.  Using this...
                        ModelingCommandData mcd;
                        mcd.op = op;
                        mcd.mode = MODELINGCOMMANDMODE_ALL;
                        mcd.doc = doc;
                        SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd);
                        BaseObject *res = static_cast<BaseObject*>(mcd.result->GetIndex(0));
                        PolygonObject *objPoly = (PolygonObject * )res;
                      Thanks again Robert!
                      ~Shawn
                        On 10/05/2011 at 09:25, xxxxxxxx wrote:
                        well..   the collision is being found now but only for the first point in the object.  It doesn't find a collision with any other point in the object.  Weird huh?
                        ~Shawn
                          On 10/05/2011 at 11:06, xxxxxxxx wrote:
                          I was just going to post that I got the same results. That it only gets the first indexed point.
                          If you find the solution. Please post it. This is something that could probably be very handy.
                            On 10/05/2011 at 11:15, xxxxxxxx wrote:
                            Nevermind that last post.  I see what your problem is.  You are returning after the first loop pass on either case.  One loop and return.
                              On 10/05/2011 at 11:26, xxxxxxxx wrote:
                              You might want to use GetNearestPoint() instead and check for a radial distance from there or modify your loop to exhaust the available point set, only taking those best matching your criteria.
                                On 10/05/2011 at 11:37, xxxxxxxx wrote:
                                LOL  oh duh.   I didn't notice that I was returning out of the loop.  Thanks for catching that.   Would GetNearestPoint() work outside of points mode?  Sorry.  I'm not home to test it. I will when I get home.
                                Thanks yet again.
                                Shaw
                                  On 10/05/2011 at 12:20, xxxxxxxx wrote:
                                  Thanks Robert.
                                  With that information I was able to change the for loop so it works with every point.
                                      Vector wtail = bd->SW(Vector(mouseX, mouseY, 0));
                                      Vector whead = bd->SW(Vector(mouseX, mouseY, 100000));
                                      cRay->Intersect(otail, !oray, 10000.0);
                                      const Real threshold = 20.0; // How close the mouse is to the point befor triggering the collision
                                          GePrint("Collision with index#:" + RealToString(i)); // Prints the point index when collided
                                  Thanks for posting this example code Shawn.
                                  It really helps me to learn this stuff.
                                    On 10/05/2011 at 14:11, xxxxxxxx wrote:
                                    Hey glad you got it working Scott.  What function are you calling this code in?  And, does your sample draw the handle at the point that is being collided with?
                                    Thanks.  ~Shawn
                                      On 10/05/2011 at 15:01, xxxxxxxx wrote:
                                      I'm not calling any function with it. Other than printing the index number of the object's point array as the mouse collides with it.
                                      The handle code doesn't do anything. I just forgot to delete it.
                                        On 10/05/2011 at 15:15, xxxxxxxx wrote:
                                        Sorry.  I wasn't clear.  I meant in what function is this code currently?  Do you have it in your Draw() function or MouseInput().  And I meant is the handle code working on your end because it wasn't working on mine but it is now.  I am thinking that this might actually be a performance monster.  I may try Roberts recommendation of using GetNearestPoint().
                                          On 10/05/2011 at 15:51, xxxxxxxx wrote:
                                          I was using it in draw. So when the mouse hovered over the point it would trigger the collide.
                                          But since you asked. I just tried putting it under the mouse input function.
                                          And while the print still works properly when the left mouse button is clicked. The handle doesn't do anything.
                                          I'm very new to this stuff. So I might not be writing it properly. Or the same way as you.
                                          So here's my MouseInput code in case you're curious:
                                          Bool DrawTool::MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg)
                                            if (!doc) return FALSE;
                                            BaseContainer state;
                                            while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the left mouse button is pressed
                                            if (state.GetLong(BFM_INPUT_VALUE) == 0) break; // Break out of the loop when left mouse button is NOT pressed
                                            LONG x = state.GetLong(BFM_INPUT_X);
                                            LONG y = state.GetLong(BFM_INPUT_Y);
                                            //GePrint("Left Mouse Button is pressed");
                                            BaseObject* obj = doc->GetActiveObject();
                                            if(!obj) return TOOLDRAW_0;
                                            PolygonObject *objPoly = (PolygonObject* )obj;
                                            Vector *points = objPoly->GetPointW();
                                            GeRayColResult res;
                                            if (!cRay)
                                                return TOOLDRAW_0;
                                            On 10/05/2011 at 16:29, xxxxxxxx wrote:
                                            Hmm looks like GetNearestPoint only works in Points mode
                                            And as is, this GeRayCollider code runs super slow when there are a lot of points.
                                            Here's what I have,  I am doing it in the draw because I want it to update live..  😉  Which I could probably do more effectively in GetCursorInfo() or write my own function and call that from the Draw() but this is mostly for testing.  🙂
                                              AutoAlloc<ViewportSelect> vps;
                                              if(!vps) return TOOLDRAW_0;
                                              BaseObject* op = doc->GetActiveObject();
                                              if(!op) return TOOLDRAW_0;
                                              bd->SetMatrix_Matrix(op, Matrix());
                                              mcd.op = op;
                                              mcd.doc = doc;
                                              if (!cRay)
                                                  return TOOLDRAW_0;
                                                  Vector whead = bd->SW(Vector(cursorX, cursorY, 100000));
                                                  if(dist <= threshold){
                                                      bd->SetPen(Vector(1,0,0));
