    C++ Plugins with Cython ?
    9 Posts 0 Posters 1.7k Views
      On 06/05/2011 at 13:28, xxxxxxxx wrote:
      As the title says: Would it be possible to write C++ Plugins using Cython ? Or maybe PyRex ?
      Niklas
        On 06/05/2011 at 13:32, xxxxxxxx wrote:
        If they compile compatible modules for CPython yes, otherwise no.
          On 06/05/2011 at 13:48, xxxxxxxx wrote:
          I'm not sure if I understood you right.
          I'd need a Cython module providing the Cinema 4D C++ API ?
          It would be genius being able to write C++ Plugins in Cython or even Python. 🙂
            On 06/05/2011 at 15:19, xxxxxxxx wrote:
            What exactly are you trying to achieve? For sure you can extend Python in C4D with own modules, if written in C, C++ or Python code.
            If you use Cython or PyRex please check if the output is compatible with CPython. (from what I've read in the docs of Cython its possible).
              On 07/05/2011 at 02:09, xxxxxxxx wrote:
              Hm, I've thought I may be able to use C++ Functions and classes in Python that are not yet implemented in Py4D then. 😄
                On 07/05/2011 at 04:21, xxxxxxxx wrote:
                If the wrapped function uses member of the OperatingSystem of C4D then no.
                  On 07/05/2011 at 07:01, xxxxxxxx wrote:
                  I don't see any advantage in that.
                    On 07/05/2011 at 09:11, xxxxxxxx wrote:
                    Well, there's still a lot of stuff that's not possible with Py4D yet, but with C++.
                    For example Shaderplugins or inserting Shaders into Materialchannels.
                      Check out BaseList2D.InsertShader and the example in the doc.
