    How To Get At Shader Options?
    14 Posts 0 Posters 1.2k Views
      On 05/05/2011 at 12:01, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Sorry. Noob question again.
      I know how to add a shader to one of the channels:
        BaseMaterial *mat = doc->GetFirstMaterial(); // Get the first material and assign a variable to it
        if(!mat) return TRUE; // Error handling
        BaseContainer *data = mat->GetDataInstance(); // Get the material's container
        BaseShader *shd = BaseShader::Alloc(Xsimplenoise); // Creates simple noise instance....For other types(fresnel,etc..). Look up  "enum Xbase"  in the SDK
        if(!shd) return FALSE;
        data->SetLink(MATERIAL_COLOR_SHADER, shd); // Adds simple noise to the color channel in memory only
        mat->InsertShader(shd, NULL); // Adds simple noise to the channel from memory
        mat->Message(MSG_UPDATE); // update the changes
        mat->Update(TRUE, TRUE); // updates the material icon
      But once I add a shader(fresnel, gradient, simplenoise, ect.) to the channel. How do I drill into that shader so I can change the parameters in them?
        On 06/05/2011 at 06:18, xxxxxxxx wrote:
        As with every class derived from BaseList2D you can simply access it's container, either through GetDataInstance() or C4DAtom::Get/SetParameter(). Basically the same as you would change object or tag parameters.
          On 06/05/2011 at 07:48, xxxxxxxx wrote:
          Thanks for the reply.
          I've been trying to use the Get/SetParameter() method. like this:
          shd->SetParameter(DescID(NOISESHADER_SCALEX), GeData(2.0), DESCFLAGS_SET_0);
          I wasn't even sure if using this was the right method to get at the data. So thanks for confirming that for me.
          But NOISESHADER_SCALEX produces an undefined error.
          I must be missing something really simple.
            On 06/05/2011 at 10:10, xxxxxxxx wrote:
            You will probably need to include the header from the resource/modules/shader/res/description folder.
              On 06/05/2011 at 10:25, xxxxxxxx wrote:
              Once again..You saved my butt Robert. 👍
              I got the ID: NOISESHADER_SCALEX by dragging from the dialog into the console.
              But I could not find any reference to this ID anywhere in my file structure.
              I have been using the built-in Windows Vista search option. And it usually finds things like this for me very well. But in this case it failed me.
              Do you have a favorite program, or method, you use search through all of the files for specific ID's?
              It looks like I can't trust the Windows search anymore.
                On 06/05/2011 at 10:44, xxxxxxxx wrote:
                Windows 7 search seems to do the trick every time.  😄  "Hint Hint"  HAHA
                  On 06/05/2011 at 10:47, xxxxxxxx wrote:
                  Even the Windows 7 search can be trick-y. 🙂
                  I use something called Agent Ransack.  It works brilliantly!
                    On 06/05/2011 at 11:10, xxxxxxxx wrote:
                    I'll check it out.
                    But..I'm stuck again. (Don't kill me. I'm trying hard Embarrassed).
                    Now I need to know how to change the gradient knots.
                    All I can find is examples on creating brand new gradients from scratch using the gradient class.
                    But what I need to know is just how to change the .pos values and the Vector() values of the two existing knots.
                    I'll post the complete code when I'm done. So anyone else new to this stuff doesn't have to ask you guys these same simple questions over again.
                      On 06/05/2011 at 13:43, xxxxxxxx wrote:
                      I couldn't figure out how to edit existing gradients. So I tried allocating a new one. And it seems to replace the old one. So I guess that will work. *shrug*
                      Here's the entire plugin code:
                      #include "c4d.h"
                      #include "c4d_symbols.h"
                      #include "../../cinema4dsdk/res/description/xsdkgradient.h"
                      #include "../../modules/shader/res/description/xnoise.h"
                      #define PLUGIN_ID    10000010 // ID FOR TESTING ONLY!!!!!!!!!!
                      class SimplePlugin : public CommandData
                            SimplePlugin(); //The Constructor
                            virtual Bool      Execute(BaseDocument *doc);
                      SimplePlugin::SimplePlugin() // The Constructor
                        //not used in this example
                      Bool SimplePlugin::Execute(BaseDocument *doc)
                        if(!shd) return FALSE; // Error handling
                        data->SetLink(MATERIAL_COLOR_SHADER, shd); // Adds a SimpleNoise shader to the color channel in memory only
                        BaseContainer *shddata = shd->GetDataInstance(); // Get the shader's container
                        AutoAlloc<Gradient> gradient; // Creates a new gradient
                        if (!gradient) return FALSE; // Error handling
                        GradientKnot k1,k2;           // Create two variables to hold the two knot values
                        k1.col = Vector(0.0,0.0,0.0); // First knot's color is black
                        k1.pos = 0.0;                 // First knot's position
                        k2.col = Vector(1.0,1.0,1.0); // Second knot's color is white
                        k2.pos = 1.0;                 // Second knot's position
                        gradient->InsertKnot(k1);  //Adds the First knot from memory
                        gradient->InsertKnot(k2);  //Adds the Second knot from memory
                        shddata->SetData(SDKGRADIENTSHADER_COLOR,GeData(CUSTOMDATATYPE_GRADIENT,gradient)); // Executes the knot changes from memory
                        shddata->SetData(SDKGRADIENTSHADER_MODE,GeData(1)); //Sets the mode<---BROKEN!!
                        shd->SetParameter(DescID(NOISESHADER_SCALEX), GeData(5.0), DESCFLAGS_SET_0); // Sets the scaleX value
                        shd->SetParameter(DescID(NOISESHADER_SCALEY), GeData(5.0), DESCFLAGS_SET_0); // Sets the scaleY value
                        mat->InsertShader(shd, NULL); // Adds the Simple Noise to the color channel from memory with all it's settings made
                        void Free(BaseMaterial*& mat); // Free memory used in the code(not sure if this is needed)
                        return true;
                      Bool RegisterSimplePlugin()
                        return RegisterCommandPlugin(PLUGIN_ID, GeLoadString(IDS_My_Simple_Plugin), 0, AutoBitmap("icon.tif"), String("Help text Goes here"), gNew SimplePlugin);
                      I hope this helps any newbs out there get up running a lot easier.
                      The mode option is still broken. But I'm exhausted from starring at this thing. So I'm taking a break.
                      Thanks for the help guys,
                        On 09/05/2011 at 02:48, xxxxxxxx wrote:
                        There is no need to allocate a Gradient if you just want to change it in an existing shader.
                        Here is a simple example. It sets the knot's postion to a random value.
                        GeData d;
                        // get the data
                        if (shd->GetParameter(DescLevel(SLA_GRADIENT_GRADIENT), d, DESCFLAGS_GET_0))
                          //get the Gradient custom data
                          Gradient *gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT);
                          if (gd)
                              // iterate through all knots and set them randomly
                              LONG kcnt = gd->GetKnotCount();
                              Random rnd;
                              rnd.Init(436357);
                              for (LONG i=0; i<kcnt; i++)
                                  GradientKnot knot = gd->GetKnot(i);
                                  knot.pos = rnd.Get01();
                                  gd->SetKnot(i, knot);
                              // set the gradient
                              shd->SetParameter(DescLevel(SLA_GRADIENT_GRADIENT), d, DESCFLAGS_SET_0);
                              shd->Message(MSG_UPDATE);
                              EventAdd();
                        Also check the GradientShader.cpp SDK example for some more sample code.
                          On 09/05/2011 at 07:34, xxxxxxxx wrote:
                          Thank you. 👍
                            On 09/05/2011 at 10:27, xxxxxxxx wrote:
                            Still doesn't work for me. 😠
                            It looks like the problem begins when trying to get the gradient's container:
                              EventAdd();
                              //////////////////     EVERYTHING IS WORKING AT THIS POINT   /////////////////////////////////////
                             //Now lets try to access the gradient and it's parameters
                            GeData d;
                              GePrint("Is this working so far?"); //<-----Yes. This does print and proves that everything is working at this point
                              Gradient *gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT); //get the gradient's custom data
                              if (gd) GePrint("true");
                              else GePrint ("false"); // <-------Prints false. The code is broken. Starting from Gradient *gd
                                                      // We are not properly accessing the gradients container. We cannot continue until this is fixed
                            I'm sure I'm missing something really simple.
                              On 17/05/2011 at 01:45, xxxxxxxx wrote:
                              SLA_GRADIENT_GRADIENT is the wrong ID for the gradient of the Simple Noise shader. Please use NOISESHADER_COLOR instead.
                                On 17/05/2011 at 11:42, xxxxxxxx wrote:
                                Thanks for sticking with me on this. I'm almost there now. But I have one final problem.
                                I can't get the gradient's mode to change:
                                Here are my list of includes:
                                #include "c4d.h"
                                #include "../../modules/xtensions/res/description/dgradient.h"
                                And here's my code:
                                GeData d;
                                if (shd->GetParameter(DescLevel(NOISESHADER_COLOR), d, DESCFLAGS_GET_0)) // If it's a Simple Noise shader. Get it's attributes
                                  Gradient *gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT); //Get the gradient's custom data and assign it to a variable
                                   if (gd)
                                      LONG kcnt = gd->GetKnotCount(); // Get the total number of knots in case we need it later
                                      GradientKnot first = gd->GetKnot(0); //Gets the first knot
                                      GradientKnot second = gd->GetKnot(1); //Gets the second knot
                                      first.pos = 0.1;                   // Changes the first knot's position in memory only
                                      second.pos = 0.8;                 // Changes the second knot's position in memory only
                                      first.col = Vector(0.5, 0.1, 0.0);     // Changes the first knot's color in memory only
                                      second.col = Vector(1.0 , 1.0, 1.0); // Changes the second knot's color in memory only
                                      gd->SetKnot(0, first);         // Execute the first knot's changes from memory
                                      gd->SetKnot(1, second);        // Execute the second knot's changes from memory
                                      // Set the gradient changes
                                      shd->SetParameter(DescLevel(NOISESHADER_COLOR), d, DESCFLAGS_SET_0);
                                      EventAdd();
                                  shd->Message(MSG_UPDATE); // Tell C4D that we made some changes
                                  EventAdd(); // Update the scene changes
                                  shddata->SetData(GRADIENTSUBCHANNEL_INTERPOLATION,GeData(GRADIENTSUBCHANNEL_INTERPOLATION_SMOOTHKNOT)); //<-----------Does Not Work! Mode does not Change!
                                  return true;
                                Any idea what I'm doing wrong with the mode code?
