    DrawTexture in DRAWPASS_HANDLES [SOLVED]
    10 Posts 0 Posters 741 Views
      On 05/05/2011 at 07:43, xxxxxxxx wrote:
      Cinema 4D Version:   R12.043
      Hi everybody,
      I want to Display some text on screen which only should be drawn when my object is selected. To achieve this I create a GeClipMap at Viewport-resolution and draw the strings onto it. At the end I draw it on Screen using the DrawTexture function. This works fine in DRAWPASS_OBJECT but in DRAWPASS_HANDLES nothing is drawn on screen.
      Thanks for any help!
      Satara
        On 05/05/2011 at 09:23, xxxxxxxx wrote:
        Yes that is right. What exactly is your question?
          On 05/05/2011 at 16:14, xxxxxxxx wrote:
          Is it not possible to use drawtexture in drawpass_handles?
            On 05/05/2011 at 17:18, xxxxxxxx wrote:
            Apparently not. 🙂 Didn't work for me either.
              On 06/05/2011 at 01:52, xxxxxxxx wrote:
              ok thanks!
                On 10/05/2011 at 01:14, xxxxxxxx wrote:
                Another problem:
                How can I draw the Text in front of the geometry (with drawtexture)?
                This is how it looks currently:
                here is the code:
                DRAWRESULT Draw(BaseObject *op, DRAWPASS drawpass, BaseDraw *bd, BaseDrawHelp *bh) {
                if (drawpass == DRAWPASS_OBJECT)
                // render the clip map to the viewport
                bd->SetMatrix_Screen();
                bd->SetLightList(BDRAW_SETLIGHTLIST_NOLIGHTS);
                Vector pnts[4] = { Vector(0, 0, 0), Vector(0, height, 0), Vector(width, height, 0), Vector(width, 0, 0) };
                Vector cols[4] = { Vector(1, 1, 1), Vector(1, 1, 1), Vector(1, 1, 1), Vector(1, 1, 1) };
                Vector nrms[4] = { Vector(0, 0, -1), Vector(0, 0, -1), Vector(0, 0, -1), Vector(0, 0, -1) };
                Vector uvs[4] = { Vector(0, 0, 0), Vector(0, 1, 0), Vector(1, 1, 0), Vector(1, 0, 0) };
                bd->DrawTexture(clipMap->GetBitmap(), pnts, cols, nrms, uvs, 4, DRAW_ALPHA_NORMAL, DRAW_TEXTUREFLAGS_INTERPOLATION_NEAREST);
                  On 17/05/2011 at 03:55, xxxxxxxx wrote:
                  Draw it in the handles drawing pass. Also make sure to use a clockwise texture polygon e.g. { Vector(0,0,0), Vector(1,0,0), Vector(1,1,0), Vector(0,1,0) }.
                  Example:
                  DRAWRESULT RoundedTube::Draw(BaseObject *op, DRAWPASS drawpass, BaseDraw *bd, BaseDrawHelp *bh)
                    if (drawpass!=DRAWPASS_HANDLES) return DRAWRESULT_SKIP;
                    Vector padr[4] = { Vector(200,200,0), Vector(300,200,0), Vector(300,300,0), Vector(200,300,0) };
                    Vector cadr[4] = { Vector(1,1,1), Vector(1,1,1), Vector(1,1,1), Vector(1,1,1) };
                    Vector nadr[4] = { Vector(0,0,-1), Vector(0,0,-1), Vector(0,0,-1), Vector(0,0,-1) };
                    Vector uvadr[4] = { Vector(0,0,0), Vector(1,0,0), Vector(1,1,0), Vector(0,1,0) };
                    bd->DrawTexture(bmp, padr, cadr, nadr, uvadr, 4, DRAW_ALPHA_NONE, DRAW_TEXTUREFLAGS_0);
                    return DRAWRESULT_OK;
                    On 17/05/2011 at 04:53, xxxxxxxx wrote:
                    Ah! Cool. thx, very good to know 🙂
                      On 17/05/2011 at 12:39, xxxxxxxx wrote:
                      Looks perfect, thx a lot Matthias!
                        On 06/08/2014 at 19:40, xxxxxxxx wrote:
                        Hi All, but if is draw in the Handle time, the texture will be not visibile if the object is not selected.
                        regards
                        Renato
