    Call function from main thread
    8 Posts 0 Posters 2.0k Views
      On 12/04/2011 at 10:07, xxxxxxxx wrote:
      the python documentation states for DrawViews(...) :
      "Redraws the editor views. Must be called from the main thread!"
      So, how do I control which thread is calling my Python Node (or how to know which thread is calling)?
      When I try to call the "add" button within the Mograph-Multishader by python:
      multishader = material[c4d.MATERIAL_COLOR_SHADER];
      c4d.CallButton(multishader, 1002) #MGMULTISHADER_ADD = 1002,
      I get the error:
      RuntimeError: Illegal operation. Invalid cross-thread call.
      This happens from a Python Node within XPresso.
      How can I prevent/control that ?
      Thank you,
      maxx
        On 12/04/2011 at 12:14, xxxxxxxx wrote:
        This is not documentated for nodes yet. The hooks for Python in the Python Generator, Python Tag and Python Node are called in a threaded context. Within this hooks you should never call GUI stuff or change the document hierarchy. Methods which are called in a threaded context are documentated with this note:
        Important: This function is called in a thread context.
        _
        _
        What exactly do you want to achieve? Maybe there is a workaround for this.
          On 12/04/2011 at 14:23, xxxxxxxx wrote:
          Hy there,
          my goal is to automate the loading of Bitmap-Shaders into the MoGraph multi-shader.
          I already tried to insert the shader directly to the multishader:
          shn = c4d.BaseList2D(c4d.Xbitmap)
          mat[c4d.MATERIAL_COLOR_SHADER] = shn
          material.InsertShader(shn,sh)
          material.Message(c4d.MSG_UPDATE)
          material.Update(True,True)
          But this will not work. Actually, the shader is in the (internal) list, but it won't show up in the multi-shader and also has no effect.
          So I tried to use the "Add" button, to add the shaders. Yea, desperate measures 😉
          Is it then possible to add a hook from within a Python Node which gets called by the main-thread?
          Can you give me an example, how to use that CallButton(..) function in the right context ?
          Thank you,
          maxx
            On 01/06/2011 at 09:35, xxxxxxxx wrote:
            Sorry for the late reply. I will check out if I can provide you with an example.
              On 02/06/2011 at 08:26, xxxxxxxx wrote:
              .. that would be nice, thank you
                On 21/04/2014 at 13:36, xxxxxxxx wrote:
                curious if you ever found a solution. Running into this now too. Seems kind of silly we can't call a button in a pynode
                  On 02/05/2014 at 06:27, xxxxxxxx wrote:
                  It's by design. A button could do things that you really don't want to happen from an Expression.
                  Use c4d.SpecialEventAdd() and listen to it with a MessageData plugin. That's one of the work arounds,
                  but it's not possible without coding a real plugin.
                  -Niklas
                    On 02/05/2014 at 16:06, xxxxxxxx wrote:
                    Dang! I'll look into the SpecialEventAdd. Thanks Niklas.
