    GetSegmentCount() always returns 1?
    3 Posts 0 Posters 730 Views
      On 11/04/2011 at 10:22, xxxxxxxx wrote:
      I'm testing the SplineHelper class functions. But for some reason GetSegmentCount() always returns the value of one. Even though my spline has multiple segments.
      Any idea what I'm doing wrong here?:
      from c4d import gui
       sh = c4d.utils.SplineHelp()
       sh.InitSpline(op, rail=None, target_rail=True, use_deformed_points=True, force_update=True, use_global_space=True)
       segCount = sh.GetSegmentCount()#Counts the total number of segments
       segLength = sh.GetSegmentLength(0)#Gets the length of the first segment
       totalLenght = sh.GetSplineLength()#Gets the length of the entire spline
       print segCount
       print segLength
       print totalLenght
        On 11/04/2011 at 11:16, xxxxxxxx wrote:
        It returns '2' here which is the correct value.
        This is the spline I've tested:
        Cheers, Niklas
          On 11/04/2011 at 12:01, xxxxxxxx wrote:
          Doh!
          I guess I got confused about how these classes decide what a "segment" is.
          After looking through my Coffee notes. I realized that what I was trying to do required using the SplineLengthData class.
          Not the SplineHelp class.
          Like this:
          from c4d import gui
            length = c4d.utils.SplineLengthData(op[0])#Creates a new instance of the SplineLengthData class
            length.Init(op,0)# Initializes the spline object(op) and the first spline segment
            print(length.GetLength())# The Spline's Length
            print(length.GetSegmentLength(0,1))#The first segment's length
            length.Free()#free up the memory used by the new SplineClass instance
