    Dynamic Variable Name?
    5 Posts 0 Posters 734 Views
      On 05/04/2011 at 00:37, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hi everyone.
      Is there a way to dynamically construct a variable name?
      E.g. I have variables Title1, Title2, Title3, and so on (it's a big list).
      I want to use a loop to set each Title variable rather than manually specify each Title.
      Is there a way for me to construct the variable name and then assign a value to it?
      Just to clarify, arrays won't work for me because these Title(n) variables are outputs on an Xpresso COFFEE node.
        On 05/04/2011 at 01:58, xxxxxxxx wrote:
        No, that's not possible.
          On 05/04/2011 at 02:47, xxxxxxxx wrote:
          Hello Eikonoklastes,
          Because all your outputs are defined in the node, you can do this:
          Output(number, data)
              switch (number)
                  case 0:
                      Output0=data;
                  case 1:
                      Output1=data;
                  case 2:
                      Output2=data;
                  case 3:
                      Output3=data;
                  default:
                    break;
              var i;
              var myArray = new(array,4);
              myArray[0] = 123;
              myArray[1] = 0.456;
              myArray[2] = 11.1;
              myArray[3] = -234;
              for(i=0; i<4;i++)
                  Output(i, myArray[i]);
            On 05/04/2011 at 03:21, xxxxxxxx wrote:
            This is possible in Python. You can iterate over ports of a node(to get the name) or any variable in any scope and read/set it's values.
              On 28/04/2011 at 04:10, xxxxxxxx wrote:
              Just some samplecode (Python) :
              \>>>locs = locals()
              \>>>for i in range(20) :
                     locs['number%s'%i] = i
              \>>>print number1,number5,number17,number19
              1 5 17 19
              \>>>print number20
              <type 'exceptions.NameError'>
              name 'number20' is not defined
              <traceback object at 0x5fca7d4>
