    Multiple dialogs
    9 Posts 0 Posters 675 Views
      On 03/04/2011 at 06:41, xxxxxxxx wrote:
      Cinema 4D Version:   11.5&12
      Platform:   Windows  ; Mac  ;
      Hi !
      I created a MenuPlugin that opens a dialog, my  problem is that each time I run the menuplugin its opens a new instance of the dialog ... I tried multiple tricks but didn't really found the equivalent of the MultipleAllowed() of the expression tag plugin.
      Any idea welcome.
      Thanks !
      Mike
        On 03/04/2011 at 07:06, xxxxxxxx wrote:
        Could you provide a snippet of code to show how you call for the dialogue to open?  Might help us help you.  🙂
        Shawn
          On 03/04/2011 at 08:49, xxxxxxxx wrote:
          Simply :
          Plugin::Execute(doc)
                dialog = new(plugintools_gui);
                dialog->Open(TRUE,-1,-1);
          plugintools_gui is a GeDialog derived class and Plugin a menuplugin
          Hope it's enough.
            On 03/04/2011 at 10:07, xxxxxxxx wrote:
            is it possible to check if there is an instance dialog already in use?
              On 03/04/2011 at 12:14, xxxxxxxx wrote:
              hello,
              first of all use restorelayout metod in dialog and command ....
              then if you need a pointer to the dialog from other part of cinema you have to create a kind of singletone of your command data and retrive the pointer from it.
              in activeobject there is an example of this! if you need some more help tell me .. i can share some example.
              all the best
              Franz
                On 03/04/2011 at 12:15, xxxxxxxx wrote:
                sorry i never seen is a coffee problem ... my reply was refereed to c++ 😞
                sorry
                Franz
                  On 03/04/2011 at 13:25, xxxxxxxx wrote:
                  Thanks Franz... No problem, I often have this problem too 🙂
                  Shawn :
                  In fact I already tested something like
                  if (!dialog)
                  But even when closed, the dialog object stays as existing. The result in cinema4d is that once I close the plugin dialog I cannot run it anymore because if (!dialog) always returns false.
                  Mike
                    On 03/04/2011 at 15:51, xxxxxxxx wrote:
                    Here is how I do it.  It will not reopen the dialog if already open and supports adding it to the layout:
                    // dropobject.cof
                    // Drop object onto target object or floor (X-Z plane).
                    // - If no object intersection, alert user.
                    // V0.3 2005.02.20 (c) Robert Templeton
                    // Included symbols
                    include "c4d_symbols.h"
                    // Global references
                    var resource;
                    var plugin_path;
                    var plugin_icon;
                    var d;
                    include "floordialog.h"
                    // CLASS: Drop Object Menu - Register plugin in menu
                    class DropObject_MenuPlugin : MenuPlugin
                          DropObject_MenuPlugin();
                          GetID();
                          GetIcon();
                          GetName();
                          GetHelp();
                          Execute(doc);
                          RestoreLayout(secret);
                    DropObject_MenuPlugin::DropObject_MenuPlugin()    { super(); }
                    DropObject_MenuPlugin::GetID()                        { return PLUGIN_MENU_ID; }
                    DropObject_MenuPlugin::GetIcon()                        { return plugin_icon; }
                    DropObject_MenuPlugin::GetName()                        { return resource->GetString(PLUGIN_MENU_TEXT); }
                    DropObject_MenuPlugin::GetHelp()                        { return resource->GetString(PLUGIN_MENU_HELP_TEXT); }
                    DropObject_MenuPlugin::Execute(doc)
                      // Perform operation
                      d->Open(TRUE,-1,-1);
                    DropObject_MenuPlugin::RestoreLayout(secret)
                      // Called by C4D to restore the dialog
                      if (!d) d = new(FloorDialog);
                      d->RestoreLayout(secret);
                    // Start of plugin
                      // Load Resource
                      if (!(plugin_path = GeGetRootFilename())) println("Unable to find plugin!");
                      plugin_path->RemoveLast();
                      if (!(resource = new(GeResource, plugin_path))) println("Unable to load resource!");
                      // Load Icons
                      var icon_file = plugin_path->GetClone();
                      icon_file->AddLast("pluginicon.tif");
                      plugin_icon = new(BaseBitmap,1,1);
                      plugin_icon->Load(icon_file);
                      // Register Plugins
                      Register(DropObject_MenuPlugin);
                      // Create non-modal dialog
                      On 03/04/2011 at 16:34, xxxxxxxx wrote:
                      Ok, so if I understand well, the key was to declare the floordialog object only ONE time when launching cinema4d, this way it avoids to get multiple instances ...this is as brilliant as it seems obvious now ...
                      You're my hero once more
                      Thanks everyone.
                      M!ke
