    move the axis ??
    3 Posts 0 Posters 844 Views
      On 01/04/2011 at 04:58, xxxxxxxx wrote:
      Hi.
      I want to move the axis of the object in a script.
      What should be carried out in what way?
        On 01/04/2011 at 05:56, xxxxxxxx wrote:
        I don't know a comfortable way to solve this. You have to move the points of the Object, instead of the axis itself, and then move the hole object (including the axis of course ;] ) again in that negative direction..
        Try this example 😉
        from   c4d import gui
        def err_message() :
          gui.MessageDialog("Please enter a vector!")
          vec       = gui.InputDialog("X Axis Offset","c4d.Vector(0,100,0)")
          try: vec  = eval(vec)
          except: pass
          if not isinstance(vec,c4d.Vector) :
              err_message()
              return False
          print     "Axis Offset: %s" % vec
          points    = op.GetAllPoints()
          for i in range(len(points)) :
              points[i] = points[i]+(vec*(-1))
          op.SetAbsPos(op.GetAbsPos()+vec)
          op.SetAllPoints(points)
          op.Message(c4d.MSG_UPDATE)
        Greets, nux
          On 01/04/2011 at 20:58, xxxxxxxx wrote:
          Thanks Nux
          'll try this way!
