    ObjectPlugin And Hide the Childrens
    3 Posts 0 Posters 799 Views
      On 19/03/2011 at 15:36, xxxxxxxx wrote:
      Hi Can i make plugin like HyperNurbs , i want to make only the method no the Formula
      to explane what i mean
      In HyperNurbs
      for example i create one new object hypernurbs and i put as Childer one cube
      when i do this i see the cube change and hide original and make new with hypernurbs
      also if i click Make Editable Command i have only one object with HyperNubrs and the original delete automatic
      -----Object List------
      +HyperNurbs
        - Cube
      the question is how can do this with python ?
      to make this method to hide and delete when i click Make Editable Command
      i don't want use for example
      the method i use now but dosen't work correct 😞
      because this hide the object and when i make editable keep the original
      here for example
       opa=op.GetDown()
       opa.SetEditorMode(c4d.Mode_OFF)
       return c4d.BaseObject(c4d.Ocube)
      i hope understand
      Thank you
        On 19/03/2011 at 17:10, xxxxxxxx wrote:
        What do you want being done as your Object is "made editable" ?
        Maybe the __del__(self) function will help you. This is called as the classintance is being deleted. Maybe it also is called when it's made editble.
        Cheers,nux
          On 19/03/2011 at 17:42, xxxxxxxx wrote:
          thank you Nux95 for quick reply
          but i think you don't understand me so i explane
          another example in cineam4d Create ExtrudeNurb Object
          and create Spline Rectangle
          when you put the Spline Rectangle as Childer in Extrude Nurbs
          +ExtrudeNurb
           -Spline Rectangle
          The Spline Hide and Make Polygon
          The First i ask is How i can use same method to hide the object
          the second i ask if i Select The Extrude Nurb and i click Make Editable
          this make 3 new Objects , Extrude NURBS , Cap 1 , Cap2
          i don't wan't the formula Extrude Nurb only the method for the Childer object how can hide or to have same results .
          Test This
          now try make a Python Genarate
          put Spline Rectangle first you see is Spline Rectangle is Visible
          and second when you click Make Editable
          Make new Cube because of the code write for begin , and second the Spline Rectangle still there 😞
          so i ask if there is anyway to hide the Spline Rectangle when i put
          as Chidler in Python Genarator
          and when i make editable the Python Genarate
          so create only the cube and delete the Spline Rectangle,
          in Python Genaretor or in Plugin Object
          i hope understand me now
          thank you
