    Getting parameter from dialog
    20 Posts 0 Posters 1.8k Views
      On 14/03/2011 at 17:44, xxxxxxxx wrote:
      In fact this is not an async dialog.
      So with the GetCheckbox() I can get a value from a closed dialog ?
      Unfortunately I hadn't time to test it tonight, but there are some answers that will really help me.
      I also agree that it would be very nice to have a kind of "map" from maxon explaining where and why it is better to put the main code.
      Thanks all !
        On 14/03/2011 at 23:23, xxxxxxxx wrote:
        You should have told me !
        Yes, the data is stored in the object even if the dialog is closed.
        I agree, too, would be very nice.
          On 15/03/2011 at 01:26, xxxxxxxx wrote:
          🙂 Thanks again !
          I can't wait to test all this tonight !
          Mike
            On 16/03/2011 at 05:53, xxxxxxxx wrote:
            Hi again !
            When I call back a Checkbox (once the dialog is closed) it always returns 0, even if it was ticked.
            I'm using dialog->GetCheckbox(ID)
            Any idea ?
            Mike
              On 16/03/2011 at 07:14, xxxxxxxx wrote:
              It should work. Please post some code.
                On 16/03/2011 at 13:46, xxxxxxxx wrote:
                Hoping it'll be enough...
                _
                _
                 _ptools_gui::CreateLayout()
                      var ret = LoadDialogResource(IDD_PTOOLS,PLUGIN_RES,BFH_SCALEFIT |BFV_SCALEFIT);
                      SetTitle(" P Toolbox v"+PTools_version);
                      return ret;
                ptools_gui::Init()
                ptools_gui::Command(id,msg)
                    switch (id)
                    case B_CANCEL:
                          Close();
                          break;
                    case B_OK:
                           Close();
                     default:
                return FALSE;
                class PTool_plug : MenuPlugin
                        PTool_plug();
                        GetName();
                        GetID();
                        GetIcon();
                        UseMenu();
                        GetHelp();
                        Execute(doc);
                PTool_plug::PTool_plug()
                    super();
                PTool_plug::UseMenu() {return TRUE;}
                PTool_plug::GetName() {return "PTool";}
                PTool_plug::GetID() {return PLUGIN_ID;}
                PTool_plug::GetIcon() {return icon_map;}
                PTool_plug::Execute(doc)
                dialog = new(ptools_gui);
                dialog->Open(FALSE,-1,-1);
                  if (dialog->GetCheckbox(P_PATH))
                      println("on");
                  else
                      println("off");
                _ _
                _
                Mike
                Edit: sry for noobism I'll post code with indentation and tags.
                  On 16/03/2011 at 14:08, xxxxxxxx wrote:
                  I'm having a look at it.
                  By the way, using indentation and posting the code in a [\\\code] [\\/code] Block (without \\\) would
                  make it much more readable.
                  Cheers, nux
                  You've obviosly derived your dialog class from GeDialog. Otherwise 'dialog->Open(FALSE,-1,-1)' would raise an error.
                  There is an additional subclass for modal dialogs. (GeModalDialog)
                  But I can't imagine this is the reason for the problem.
                  The title is set in Init(). Do never forget return values for overloaded functions, even they're blank. (For eg Init())
                  But couldn't figure out the real problem yet.
                    On 16/03/2011 at 15:07, xxxxxxxx wrote:
                    Ok Thanks for your advices once more... I'll give a try with ModalDialog.
                    Mike
                      On 16/03/2011 at 20:58, xxxxxxxx wrote:
                      I'm still a learner with this plugin stuff. So take this advice with a grain of salt.
                      If you're wanting to get the state of the checkbox when you close the dialog window with the "OK" button. Then give this a try:
                        switch (id)
                          case BUT_CANCEL:
                                Close();
                                break;
                          case B_OK:
                             if(dialog->GetCheckbox(P_PATH))
                                println("ON");
                             else{
                                 println("Off");
                               Close();
                      I've been told that switches are supposed to be used in place of if statements. And putting if's inside of switches is wrong.
                      However, sometimes it's necessary to use nested if statements to do things. So in this case it makes sense to me to use them together.
                      As I said...I'm still learning. So take this advice as something coming from a learner.
                        On 17/03/2011 at 01:34, xxxxxxxx wrote:
                        My goal is to be able to reach this on or off value once the dialog is closed.
                        This won't be enough.
                        Anyway, thanks ScottA
                          On 17/03/2011 at 07:36, xxxxxxxx wrote:
                          Could you solve the problem ?
                            On 17/03/2011 at 07:48, xxxxxxxx wrote:
                            Is that even possible to do with a dialog?
                            ASFAIK. Once a dialog closes. Everything in it is deleted from  memory and can't be accessed until the dialog is opened again.
                            My understanding is the only way to store things is by using a tag plugin. Since the tag is always there. It can be used to hold a value(in this case a state value). And you can even make tag's invisible to use them as hidden storage containers.
                            But I could be wrong.....
