    Tag Plugin Attribut - UI element refresh
    4 Posts 0 Posters 1.1k Views
      On 12/03/2011 at 07:28, xxxxxxxx wrote:
      Hi guys,
      another day another problem. I'm trying to change the state of a simple checkbox from within my tag plugin. The checkbox has the ID 10000, so this is what I do.
      bc = tag.GetData()
      print bc.GetBool(10000) # this correctly comes back True or False
      bc.SetBool(10000,True)
      -> this does internally change the value, but does not update the UI, so next frame the setting if forgotten!
      I tried all of these to no avail:
      op.Message(c4d.MSG_UPDATE)
      tag.Message(c4d.MSG_UPDATE)
      c4d.EventAdd(c4d.EVENT_NOEXPRESSION)
      Nothing does it.
      Updating user data from a regular Python tag works fine, it's only once I have it running as a Tag plugin that it does not work any more.
      Any ideas anyone?
        On 12/03/2011 at 08:09, xxxxxxxx wrote:
        Well, what about setting the Container back to your tag ?
          On 12/03/2011 at 10:24, xxxxxxxx wrote:
          Doh! Overlooking the obvious again, aren't I.... thanks mate, that was exactly it 🙂
            On 12/03/2011 at 11:16, xxxxxxxx wrote:
            tag.GetData() returns a new copy of the settings container, use GetDataInstance() instead to get the internal container.
