Write Strings into HyperFile ?
On 11/03/2011 at 14:39, xxxxxxxx wrote:
Hi there,
i want to write a string into a hyperfile. But i don't want that string being compiled or something. It should just be a string in the file.
How to do that ?
Thanks, nux
On 12/03/2011 at 10:06, xxxxxxxx wrote:
What do you mean with "being compiled"?
To save a string in a hyperfile check out this example:
import c4d from c4d import gui, storage #Welcome to the world of Python path="/path/to/file/test.xyz" ident=123456 #file identifier def write() : hf=storage.HyperFile() hf.Open(ident, path, c4d.FILEOPEN_WRITE, 0) hf.WriteString("Hello World!") hf.Close() def read() : hf=storage.HyperFile() hf.Open(ident, path, c4d.FILEOPEN_READ, 0) c=hf.ReadString() print c #ouput: Hello World! hf.Close() if __name__=='__main__': write() read()Cheers, Sebastian
On 12/03/2011 at 13:24, xxxxxxxx wrote:
With 'being compiled' I mean, the written String is not formatted as if I would write it into the File myself.
It's kind of "compiled". Is it MD5 ? Dunno, but it's not a usual String.
Int your example it's like this:QC4D â@ / ' H e l l o W o r l d !I already made a couple of Plugins with files in Coffee and Python.
But in Coffee, writing a String to BaseFile works as I want it in this case.Finally, I want to write an XML Exporter, I already imported the pyfo Package to Py4D.
For XML I need "real" strings, even the actual way data is being to files by the HyperFile class ia very useful, too.And some extra questions by the way
:- How to browse a directory on harddrive?
- How can I deliver necessary Packages not
installed by default with my Plugin ?
- Would it be possible to write a Py4D Package in order to extend it with functions from C++ not implemented by you ?Much Thanks in Advance,
Niklas -
On 16/03/2011 at 14:22, xxxxxxxx wrote:
*push it to the limit*
On 16/03/2011 at 15:59, xxxxxxxx wrote:
It's kind of "compiled". Is it MD5 ? Dunno, but it's not a usual String.A HyperFile is a container format for C4D. If you want to write XML files via Python, please check the modules and types which are part of the Python core (xml module + type:file)
HyperFile!=BaseFile
Take a look at:
http://docs.python.org/library/stdtypes.html#file-objects
http://docs.python.org/library/xml.dom.html
http://docs.python.org/library/xml.dom.minidom.html- How to browse a directory on harddrive?
installed by default with my Plugin ?I recommend you to take a look at the Python documentation or tutorials (especially check the module os ).
On 16/03/2011 at 22:44, xxxxxxxx wrote:
Ahhhhhh Thanks !
I thought Basefile in Cof and HyerFile in Py are kind og the same because there is noe BaseFile class in Python and one can create HyperFiles easily which is not possible in Coffe.
I'm already on my way checking the hole Python documentation. But I did not reach FileObjects yet.
Much appreciate your help!
-Niklas
