    Merge Polygon Objects
    4 Posts 0 Posters 515 Views
      On 09/03/2011 at 04:42, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :   C.O.F.F.E.E  ;  C++  ;   PYTHON  ;
      Hi there,
      I post this in the SDK Help Subforum, because I am sure, if someone knows a way to solve my Problem in C++ I can transfer it to Python.
      What I want is to merge 2 Polygonobjects into one. If you know how to do it, you actually don't need to understand my Code. 🙂
      If not, I hope C++'ers can understand it.
      It actually works, but some points are connected with the the other objects.
      And theire axes are resetted , but I know how to fix this, and I will do this later.
      def SetAllPoints(op,points) :
        if op is None: return False
        if points is None: return False
        cnt = op.GetPointCount()
        for i in xrange(cnt) :
            op.SetPoint(i,points[i])
        op.Message(c4d.MSG_UPDATE)
      def SetAllPolygons(op,polys) :
        if polys is None: return False
        cnt = op.GetPolygonCount()
            op.SetPolygon(i,polys[i])
      def MakeEditable(op) :
        if (not op) : return
        if (op.CheckType(c4d.Opolygon) == True) : return op
        op = [op.GetClone()]
        doc = c4d.documents.BaseDocument()
        doc.InsertObject(op[0],None,None)
        op = c4d.utils.SendModelingCommand(
                                  command = c4d.MCOMMAND_MAKEEDITABLE,
                                  list = op,
                                  doc = doc )
        return op[0]
      def MergeLists(lst1,lst2) :
        for line in lst2:
            lst1.append(line)
        return lst1
      def MergePolygonObjects(obj1,obj2) :
        op = c4d.BaseObject(c4d.Opolygon)
        obj1 = MakeEditable(obj1)
        obj2 = MakeEditable(obj2)
        op.ResizeObject(obj1.GetPointCount()+obj2.GetPointCount(),obj1.GetPolygonCount()+obj2.GetPolygonCount())
        SetAllPoints(op,MergeLists(obj1.GetAllPoints(),obj2.GetAllPoints()))
        SetAllPolygons(op,MergeLists(obj1.GetAllPolygons(),obj2.GetAllPolygons()))
        return op
      Thanks in Advance, nux
        On 09/03/2011 at 05:03, xxxxxxxx wrote:
        hi there,
        you have to remap the vertex-indices of the second polygonobject. Adding an offset obj1.GetPointCount() to each vertex index in the polygon array of the second one should do it.
        greetz
          On 09/03/2011 at 08:12, xxxxxxxx wrote:
          You could use SendModelingCommand(MCOMMAND_JOIN, ...).  The only caveat is that you will need to put the editable objects under a Null object and pass the Null object in with the ModelingCommandData.  Best to make clones to work with.
            On 09/03/2011 at 09:03, xxxxxxxx wrote:
            Thanks, that should work. Haha, didn't think about this !
            Still got some problems, postet in the Python Subforum.
            https://developers.maxon.net/forum/topic/5572/5593_mcommandjoin
            Cheers, nux
