    sorting an array / list ?
    9 Posts 0 Posters 2.1k Views
      On 07/03/2011 at 23:38, xxxxxxxx wrote:
      Hi Everyone,
      I am trying to sort an array which is called list in python i guess.
      i tried
      boundingbox = activeobject.GetRad()
      print boundingbox
      alist = (boundingbox.x, boundingbox.y, boundingbox.z)
      print alist
      alist.sort()
      which gives me
      AttributeError: 'tuple' object has no attribute 'sort'
      what am I doing wrong ?
      thanks in advance
      mogh
        On 08/03/2011 at 02:05, xxxxxxxx wrote:
        as py-doc non c4d's, to sort tuple-object, seems need to use `
        itertools.permutations`( _iterable_ [, _r_ ])
        or i'm making mistake?!
        import c4d,itertools
        from c4d import gui,documents
          activeobject = doc.GetActiveObject()
          print boundingbox
          print alist
          print list(itertools.permutations(alist,2))
          #alist.sort()
          On 08/03/2011 at 05:07, xxxxxxxx wrote:
          (200.0, 24.999999999999996, 100.0)
          [(200.0, 24.999999999999996), (200.0, 100.0), (24.999999999999996, 200.0), (24.999999999999996, 100.0), (100.0, 200.0), (100.0, 24.999999999999996)]
          your script gives me this as an output, which is wiered and not sorted at all?
          still - thanks for your help
          regrads mogh
            On 08/03/2011 at 05:43, xxxxxxxx wrote:
            product('ABCD', repeat=2) AA AB AC AD BA BB BC BD CA CB CC CD DA DB DC DD
            permutations('ABCD', 2) AB AC AD BA BC BD CA CB CD DA DB DC
            combinations('ABCD', 2) AB AC AD BC BD CD
            _<_t_>_all work with tuple
            product() p, q, ... [repeat=1] cartesian product, equivalent to a nested for-loop
            permutations() p[, r] r-length tuples, all possible orderings, no repeated elements
            combinations() p[, r] r-length tuples, in sorted order, no repeated elements_/t>
              On 08/03/2011 at 06:11, xxxxxxxx wrote:
              hm I guess we missunderstand each other, i want
              (C,B,A,D) => (A,B,C,D)
              but with the single values of a vector like
              (200.0, 24.999999999999996, 100.0) => (200.0, 100.0, 24.999999999999996)
              so when i acces the first of a list
              i get the highes and when i acces the last the smallest number. There is probably a clever version for a min max but i need these 3 values sorted so min max wont do the job completely.
              by the way how do i access the first in the list ?
              alist[1] ???
              kind regards mogh
                On 08/03/2011 at 07:53, xxxxxxxx wrote:
                you created a tuple instead of a list.. try this:
                alist = [200.0, 24.999999999999996, 100.0]
                print alist
                alist.sort()
                alist.reverse()
                print alist
                print alist[0] #first element
                      print boundingbox
                      atuple = (boundingbox.x, boundingbox.y, boundingbox.z)
                      alist = list(atuple)
                      alist.sort()
                      alist.reverse()
                      print alist
                  thanks its working now, but i had to convert the tuple to a list first.
                  thanks for all your help
                  kind regards mogh
                    On 09/03/2011 at 09:14, xxxxxxxx wrote:
                    Well, can i ask Sebastian, can we manipulate tuple objects by native or in-built py-tools?
                    I see that can... or need to use conversation between data-objects as other methods  are impossible?!
                      On 11/03/2011 at 13:32, xxxxxxxx wrote:
                      Tuples aren't like lists, they are meant to be kept "as is" and you can't change their values. They are more like a "constat list". You need to convert them to a list if you want to manipulate them, that's just the way it works in Python.
