    Insert Line jump
    4 Posts 0 Posters 430 Views
      On 07/03/2011 at 06:41, xxxxxxxx wrote:
      Cinema 4D Version:   11.5-12
      Hi all !
      I didn't found how to add a line jump in a remote text file.
      When I use Basefile* WriteString() I result with a strange caracter in front of the string and I don't know how to add a line jump... Is it a special character to insert with WriteChar() ?
      Any hint ?
      Mike
        On 07/03/2011 at 09:35, xxxxxxxx wrote:
        AIUI WriteString() doesn't write a simple C character array as you might expect. It writes a C4D String object which obviously contains the text but also the other data which make it a String object. That's the odd stuff you see before the text.
        If you want to write a plain text file, you need to write your own routine to do this. This has been discussed a few times here and if you search the forum you'll find a routine by Matthias (IIRC) that does the trick very well. Others have posted similar routines.
          On 07/03/2011 at 12:00, xxxxxxxx wrote:
          Now I know what I should look for. I'll dig in the forum.
          Thank you !
            On 08/03/2011 at 00:59, xxxxxxxx wrote:
            Something like this should do the trick:
            Bool WriteString(const String &line, BaseFile* file)
              if(!file) return FALSE;
              CHAR *charline = NULL;
              LONG strlength = line.GetCStringLen(STRINGENCODING_7BITHEX);
              charline = GeAllocType(CHAR, strlength+1);
              if(!charline) return FALSE;
              strlength = line.GetCString(charline, strlength+1, STRINGENCODING_7BITHEX);
              LONG i;
              for(i=0; i<strlength; i++)
                  if(!file->WriteChar(charline[i])) return FALSE;
              GeFree(charline);
