    GvOperatorData
    5 Posts 0 Posters 586 Views
      On 27/02/2011 at 14:26, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I am trying to write and register an xpresso node plugin.  Here is what I have so far.  I am starting simple just to see if I can get something to compile.   I am running in to a problem because under the GvRegisterOperatorPlugin()   The fourth argument requires an allocation of some sort.  I try MyClass->Alloc() but Alloc() is not a member of GvOperatorData()..    Does anyone know what I should put there?
      Shawn
      #include "c4d.h"
      #include "c4d_operatordata.h"
      #include "myClass.h"
      class MyClass : public GvOperatorData{
        virtual Bool Init(GeListNode* node);
      //Init Function
      Bool MyClass::Init(GeListNode *node){
      Bool RegisterMyClass(void){
       return GvRegisterOperatorPlugin(ID_NPARTICLE_NODE, "MyClass", PLUGINFLAG_SMALLNODE, MyClass::Alloc(), "MyClass", 0, ID_GV_OPCLASS_TYPE_GENERAL, ID_GV_OPGROUP_TYPE_GENERAL, 0, AutoBitmap("MyClass.tif"));
        On 27/02/2011 at 14:37, xxxxxxxx wrote:
        Maybe I can only repeat myself but search the forum. there is a full example available (if not several).
          On 27/02/2011 at 15:33, xxxxxxxx wrote:
          Maybe i wasn't clear.  I HAVE searched the forums and all results show to use GvOperatorData::Alloc for that argument  or more specifically the class which inherits GvOperatorData.   I am doing that but it doesn't work.
          I was trying to use this example:
          https://developers.maxon.net/forum/topic/3916/3386_baseobjects-and-objectlinkports&KW=GvRegisterOperatorPlugin&PID=13868#13868
          but the sdk for r12 says that there is no Alloc() in GvOperatorData.
          This is why I am asking.  🙂
            On 27/02/2011 at 16:22, xxxxxxxx wrote:
            Any other examples that use GvRegisterOperatorPlugin() use the GvOperatorData::Alloc() for that argument so My question is, has this changed in the SDK?  Or is there a different way to do it?
            Shawn
              On 27/02/2011 at 16:35, xxxxxxxx wrote:
              Problem Solved.
              My mistake..  I cut out too much when shelling out my simple example...
              I left out...
              static NodeData* Alloc(void) { return gNew MyClass; }
              to the class methods.  🙂
              The problem is solved.
              Proof still that my forum searching skills are still in tact.  🙂
