    Copy Bitmap with GetPixelCnt
    7 Posts 0 Posters 526 Views
      On 23/02/2011 at 05:14, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      i want to copy a MultipassBitmap to my own Picturefile.
      Currently i use the GetPixelCnt function to get the Pixels LinePerLine, but it seems that i use it in the wrong way (on some PCs it crashs).
      My Code:
        void *linePtr = GeAlloc(sizeX*3); // the buffer where the Pixels per line are stored
        LONG BytesPerPixel = src->GetBt() / 8;        // src is a MultipassBitmap *
        src->GetPixelCnt(0, y, sizeX, (UCHAR* )linePtr, BytesPerPixel, COLORMODE_RGB, PIXELCNT_0); // should copy the line to the buffer
      Is it possible what the BytesPerPixel are wrong calculated (I thought the BytesPerPixel are the Bytes used for 1 Pixel in the src Bitmap => so get the bits per pixel and take it throw 8
        On 23/02/2011 at 05:30, xxxxxxxx wrote:
        Actually I I am not familiar with C++.
        What about the GetClone() function ? If you want to Copy the Bitmap, it might be useful.
        //Ah, sorry. A MultipassBitmap is not the same as a BaseBitmap. Ignore my comment. 😊
          On 23/02/2011 at 05:33, xxxxxxxx wrote:
          well i want to copy the data to my own (RGB 8bit) Pictureclass so i couldnt clone it.
            On 23/02/2011 at 06:27, xxxxxxxx wrote:
            The BFF.cpp SDK example uses the GetPixelCnt() method.
            I stripped it down to following code:
            LONG            y,bw,bh;
            UCHAR            *line = NULL;
            //bm is the bitmap
            bw=bm->GetBw();
            bh=bm->GetBh();
            line = GeAllocType(UCHAR,3*bw);
            if (!line)
              GeFree(line);
              return FALSE;
            for (y=0; y<bh; y++)
              bm->GetPixelCnt(0,y,bw,line,COLORBYTES_RGB,COLORMODE_RGB,PIXELCNT_0);
              // do something with line
            GeFree(line);
            Always free the buffer with GeFree() when you are finished.
              On 23/02/2011 at 07:04, xxxxxxxx wrote:
              ah thanks,
              could i dynamical determine which COLORBYTES an COLORMODE return by getColorMode() has?
                On 23/02/2011 at 07:31, xxxxxxxx wrote:
                Not that I know of. You have to convert COLORMODE to COLORBYTES yourself.
                something like this:
                switch (mode)
                  case COLORMODE_RGB: return COLORBYTES_RGB;
                  case COLORMODE_GRAY: return COLORBYTES_GRAY;
                  // etc.
                  On 23/02/2011 at 07:33, xxxxxxxx wrote:
                  ah ok
                  thank you very much.
