    Python GUIs
    2 Posts 0 Posters 939 Views
      On 21/02/2011 at 16:40, xxxxxxxx wrote:
      I have used Python in C4D before, but just to whip out quick scripts
      that wrote data to text files, with no user interaction(no save file dialog, no export options, etc.)
      I would like to write an exporter that fits nicely in C4D and I have a few questions:
      1. Is it possible to write an exporter that will show in the File > Export menu ?
      (If I write a plugin with Python, will it show under Python > My Plugin only,
      or it possible to make it accessible through the File > Export menu ?
      Is it possible to write a plugin that will show in the File > Export menu, how ?)
      2. How do I get started with making GUIs in Python ?
      I've noticed the gui.GeDialog class has the functionality I need, but I can't seem
      to understand where to start. How do I create a basic dialog ? Is there a sample
      somewhere ?
      Thank you for your time,
      George
        On 21/02/2011 at 22:14, xxxxxxxx wrote:
        I can't answer your first question, but the 2nd one though.
        Yes, it is possible to use GUIs with Python. You can Code
        them by yourself or you can use ResEdit.
        I didn't use Dialogs in Python yet, but in Coffee. You have to create an own class
        for the dialog there and i think its the same in Python.
        How to start ?
        Take a look into the GeDialog (or you better use a ModalDialog for an exporter, so check GeModalDialog)
        and also have a look at GeRessource. Create a dialog, save ir to your Plugin Path, load the ressource into a variable, give this ressource your Ge(Modal)Dialog-Subclass, finished. But that's just the simple explanation. :lol:
        You could also take a look into the MemoryViewer example for example. It uses a dialog, too, even the examples don't work anymore 😕
        Hopefully this helps you a little bit.
        Cheers, nux
