    Selected Keys? Move Keys?
    PYTHON Development
    0
    31
    22.4k
    • H
      On 21/02/2011 at 02:04, xxxxxxxx wrote:
      Trying to find a way to identify selected timeline keys and move them
      ie
      3 items
      3 tracks
      select a range of  keys for all three items
      move keys on the tracks by differing amounts
      essentially running c4d.CallCommand(465001216) - the Move Scale Selected Keyframe command
      on each track
      with different MOVE values
      any help appreciated
      (thanks to Scott A so far)
      • H
        On 22/02/2011 at 23:23, xxxxxxxx wrote:
        Well, to move them should not be a problem. But to find the selected ones would be ..
        I couldn't find a function doing so .. 😕
        //edit:
        I think I found it out, but I couldn't test it, yet. Try this:
        def GetSelectedKeys(curve) :
          # Returns the selected Keys in a Curve and their count
          cnt = curve.GetKeyCount()
          keylist = list()
          key_i = 0
          for i in xrange(cnt) :
              k = curve.GetKey(i)
              if k.GetBit(BIT_ACTIVE) is True:
                   l[key_i] = k
                   key_i = key_i+1
          return keylist, key_i
        If the syntax for the list obejct is wrong, please correct me. I don't understand much of them yet. 😕
        Cheers, nux
        • H
          On 23/02/2011 at 00:17, xxxxxxxx wrote:
          much appreciate the help
          • H
            On 23/02/2011 at 12:07, xxxxxxxx wrote:
            Nux.
            I have all the pieces to make this key mover script work. But half of it is in Coffee form and needs to be converted to python. And I'm horrible with python loops. So maybe you (or anyone else) can take all the parts and put them together in python?
            The goal is to move only selected keys in the timeline by an offset value.
            Coffee does not have NBit abilities. So AFAIK it can't find selected keys.
            So here is how to move all the keys on all of the tracks on an object using Coffee:
            //This script moves keys in a positive direction
            var offset = 10;// change this value as desired
            var trk = op->GetFirstCTrack();// Get the first track
            if(!trk) // Error handling if object has no tracks
             TextDialog("No tracks found on object!\n" + "Please create one", DLG_OK + DLG_ICONEXCLAMATION);
             return;
            while(trk)
              var curve = trk->GetCurve(CCURVE_CURVE, FALSE); // R12 version
              var i;
              for(i=curve->GetKeyCount()-1; i>=0 ; --i) // Get all of the keys
              var keys = curve->GetKey(i);
              var keytime = keys->GetTime(); // Get's the key's baseTime value
              var keyframe = keytime->GetFrame(30);//Get the frame the key is on based on a project setting of 30fps
              var newframe = doc->GetTime();
              newframe->SetFrame(keyframe + offset, 30); //Move the key by offset value from where it currently is
              keys->SetTime(curve,newframe); // Move the key to the value of newframe
              EventAdd(EVMSG_FCURVECHANGE);//update the F-Curve timeline changes
             trk = trk->GetNext(); // Get the next track
            Here is an example of getting only the selected keys on the first track using GetNBit() and python:
            #This code checks if any keys in the first track are selected
            from c4d import gui
              obj = doc.GetActiveObject()
              trk = obj.GetFirstCTrack()
              curve = trk.GetCurve()
               keys = curve.GetKey(i)
               if keys.GetNBit(5) is 1: # 5 is the int id for NBIT_TL1_SELECT
                print keys.GetValue() #prints the keys value
            What needs to be done is the Coffee code example needs to be converted to Python. And then combined with the GetNBit() functionality so that it loops through all of the tracks on an object. And only moves the ones that are selected by the offset value.
            I'm just not good enough with python loops yet to do this myself.
            • H
              On 23/02/2011 at 13:58, xxxxxxxx wrote:
              Yea, I'll try to write this in Python now. 🙂 I didn't know where to start, because I'm absolutely not familiar with Animation stuff and so on. .. @_@ But now I have a reference of the COFFEE Version.
              Seems like we're a good Team 😂
              I can only be on a mobile device for today, but I'll write the Raw Code on it ow and the search Bugs on  my computer tomorrow.
              I'll be back with new Infos then. 🙂
              Cheers, nux
              • H
                On 23/02/2011 at 14:33, xxxxxxxx wrote:
                Trying my best to follow this. Not sitting idly by.
                So far I can only get key values on one track.
                And the selection of key seems to depend on the object selection, rather than just a key selection
                Confused - but learning as I go. Thanks again to all
                • H
                  On 23/02/2011 at 15:34, xxxxxxxx wrote:
                  Yes. The python example I posted only loops though all the keys on a single track using a for loop.
                  In order to get the keys on the other tracks. That for loop would need to be inside of a while loop to move on to the next track. which isn't that difficult to do.
                  The hard part is that you have to get the last key first as you loop through all of this stuff. Because if you move the first keys in order. They will end up on top of eachother. And the loop will fail.
                  Think of a train pulling it's cargo cars.
                  The code in Coffee to do that looks like this: for(i=curve->GetKeyCount()-1; i>=0 ; --i)
                  Which means. Start from the last key. Then work your way back every time the loop runs.
                  I don't know how to write that kind of loop in python yet.
                  Sort of. It's a case of Parent ->Child relationships.
                  The document is the parent of all objects. So to get at objects in python you write doc.GetActiveObject(). Where doc is the parent, and the selected object is the child.
                  The same rule goes for things attached to objects.
                  -Tracks are the children of objects.
                  --Curves are the children of tracks
                  ---Keys are the children of curves.
                  So you almost never grab things directly in C4D. You get the parent. Then drill down into it's children until you reach the item you want to manipulate.
                  Hope that makes sense.
                  Edit* - I just found this with Google. Turns out it's not as hard to do a revese loop in python as I thought. In fact it's pretty darned simple:
                    for i in reversed(xrange(cnt)) :
                     if keys.GetNBit(5) is 1: # If a key is selected
                      print keys.GetValue() #print the key's value
                  We'll get it working eventually deepshade. 🙂
                  • H
                    On 23/02/2011 at 21:09, xxxxxxxx wrote:
                    Uhm. just by the way: Why do we need a reversed loop ?
                    • H
                      On 23/02/2011 at 21:55, xxxxxxxx wrote:
                      Now, i got it all work. Only thing missing is the GetNBit, cause I have not enough Time now. I'll post the full code later on. 🙂
                      But a look in the SDK makes me think that CKeys doesn't have the function GetNBit because it's a method of the GeListNode Class.. ?
                      PS: Still don't understand why you used an Invers Iteration.
                      //edit:
                      So, here's the complete function: 🙂
                      Even with Undo-Functionality 😉
                      def MoveSelectedKeys(op,offset,timeln = 1) :    # offset in frames
                        if (not op) or (not offset) : return False
                        if timeln == 1: timeln = c4d.NBIT_TL1_SELECT
                        elif timeln == 2: timeln = c4d.NBIT_TL2_SELECT
                        elif timeln == 3: timeln = c4d.NBIT_TL3_SELECT
                        elif timeln == 4: timeln = c4d.NBIT_TL4_SELECT
                            import math
                            timeln = math.fmod(timeln,4)
                            MoveSelectedKeys(op,offset,timeln)
                        doc = op.GetDocument()
                        doc.StartUndo()
                        track = op.GetFirstCTrack()
                        if not track: return False
                        fps = float(doc.GetFps())
                        while track:
                            curve = track.GetCurve()
                                key = curve.GetKey(i)
                                if key.GetNBit(int(timeln)) == True:
                                    tme = key.GetTime()
                                    doc.AddUndo(c4d.UNDOTYPE_CHANGE,op)
                                    key.SetTime(curve,c4d.BaseTime(offset/fps+tme.Get()))
                            track = track.GetNext()
                        doc.EndUndo()
                        c4d.EventAdd(c4d.MSG_UPDATE)
                      Is there a bit for keys in the "usual" timeline ? This one does only affect the selected keys in the Manager .. Confused
                      Cheers, nux
                      • H
                        On 24/02/2011 at 07:56, xxxxxxxx wrote:
                        Good job nux.
                        I like how you implemented the other timeline windows.
                        I needed to use a reverse loop in Coffee because if I had for example: keys ten frames apart and an offset value of ten. The first key would get moved on top of the last key. Then when the loop came around a second time. The keys were all on the same frame and it couldn't figure out what to move.
                        I didn't know of any other way to do it.
                        Deepshade,
                        Just in case you don't know this. What nux posted is a method.
                        So if you want to use this in the python script manager. You paste it above the def main section.
                        Then call to the method like this:
                          offset = 15 #change this value as needed
                          MoveSelectedKeys(obj,offset,timeln = 1)
                        • H
                          On 24/02/2011 at 08:34, xxxxxxxx wrote:
                          OMG 🙂 - just dropped in for a look. Middle of some exhibition visual at present. Back this evening. Will have a good read later.
                          cheers all
                          • H
                            Let me add, that in the SkriptManager op is automatically the selected Object. 🙂
                            And you don't need to overload the timeln since you don't want timeline 2,3 or 4.
                            So this works too:
                                  MoveSelectedKeys(op,offset)
                            • H
                              On 25/02/2011 at 03:47, xxxxxxxx wrote:
                              Hi All
                              Sorry for lack of contribution - yesterdays work over ran
                              try to get back to this as soon as job is out of the door
                              • H
                                On 26/02/2011 at 02:07, xxxxxxxx wrote:
                                Hi all
                                Finally escaped from the last job.
                                A couple of things
                                Confusion
                                Just to confirm - the original concept was for staggered keys on multiple objects
                                Don't get me wrong - not complaining - just need to be clear what I'm seeing
                                The code is there in the while loop looks like it iterates through all the tracks of a single selected object.
                                If I select more than one object - nothing happens? (no provision in script so far)
                                I'd assume (if you want to modify keys differently for different objects) it would be better to write a small function
                                and modify the Key value before running Key.SetTime(...etc
                                dependent on the number of selected tracks
                                Sadly I cant see a way to return the count of selected tracks (yes Scott I now see the route) - so I guess
                                the whole things needs to run in an outer loop - iterating through the selected objects?
                                Another issue  - if you modify the offset inside the While track loop
                                ie after
                                key.SetTime..
                                with something as simple as offset = offset + 10
                                Assuming you have a POS ROT SCALE tracks as well
                                Selecting all tracks is fine
                                Selecting just one track ie POS - inserts two extra sets of keyframes
                                as the while loop count is based on the total number of tracks
                                Cant see a simple solution
                                can't find reference to
                                C4d.NBIT_TL1_SELECT in the SDK - I take it these refer to the 4 timelines
                                Where did you get that info pls?
                                        import math
                                    doc.StartUndo()
                                    while track:
                                                tme = key.GetTime()
                                    doc.EndUndo()
                                    offset = 50 #change this value as needed
                                • H
                                  On 26/02/2011 at 03:06, xxxxxxxx wrote:
                                  1:
                                  You can simply use the function in an iteration through the selected objects.
                                  What means staggered ? Don't know the word ^^
                                  2:
                                  Why modifieng the
                                  key value ? I thought it's about moving keys ?
                                  And what do you want to achieve with offset = offset + 10
                                  Don't select a track, select the keys.
                                  3:
                                  It's in the GetNBits() function. Search for it without the c4d. in front.
                                  I'll can answer your questions better later when im at home in about 2 hours.
                                  Till then,
                                  cheers
                                  • H
                                    All explained here
                                    http://forums.cgsociety.org/showthread.php?f=182&t=959094
                                    with sample file (first post)
                                    file shows example of before and after stagger
                                    hth
                                    • H
                                      On 26/02/2011 at 05:23, xxxxxxxx wrote:
                                      Ah, you mean the 2nd Cube should start moving when the 1st one finished ?
                                      That shouldn't be a problem.
                                      I'll be back in a minute with a function doing this.
                                      cheers
                                      PS: Do still only the selected keys need to be moved ?
                                      //So, this is a bit more complex than i thought. 😂
                                      But it works fine 🙂
                                      from c4d import documents
                                      overlap = 20    ## Change this to the Frame you want to let the keys beeing overlapped
                                            import math
                                        while track:
                                                    tme = key.GetTime()
                                      def GetLastSelectedKey(track, timeln = 1) :
                                            import math
                                            key = curve.GetKey(cnt-i-1)
                                                return key
                                      def GetHNext(op) :
                                        if not op: return
                                        if op.GetDown() : return op.GetDown()
                                        while not op.GetNext() and op.GetUp() :
                                            op = op.GetUp()
                                        return op.GetNext()
                                      def GetActiveObjects(doc) :
                                        lst = list()
                                        op = doc.GetFirstObject()
                                        while op:
                                            if op.GetBit(c4d.BIT_ACTIVE) == True: lst.append(op)
                                            op = GetHNext(op)
                                        return lst
                                        doc.StartUndo()
                                        lst = GetActiveObjects(doc)
                                        op = lst[0]
                                        if not op: return False
                                        key = GetLastSelectedKey(op.GetFirstCTrack())
                                        if not key: offset = 0
                                        else: offset = key.GetTime().GetFrame(doc.GetFps())-overlap
                                        for i in xrange(len(lst)) :
                                            print op.GetName()
                                            op = lst[i+1]
                                        doc.EndUndo()
                                      Here a tiny Screencast to show you how to use it:
                                      " target="_blank" rel="noopener noreferrer nofollow ugc">
                                      • H
                                        On 26/02/2011 at 12:08, xxxxxxxx wrote:
                                        Hey Nux95
                                        This is just great
                                        And there's so much useful stuff here for reference
                                        It's really appreciated  - many thanks
                                        line 103
                                        op=list[i+1]
                                        is throwing an error
                                        index out of range
                                        I guess this is just incrementing one object too many? at the end of the selected objects
                                        Not wanting to take anything away from what you've done here - far beyond the call of duty 🙂
                                        I think it would be nice to have the 'processing' part of the script possibly
                                        in a function
                                        ie release a collection of key manipulating scripts - by just changing the function
                                        stagger - by offset - as we have now
                                        stagger  - by total time - total time over which to stagger all frames
                                        stagger exponentially large to small
                                        stagger exponentially small to large
                                        etc etc
                                        cheers again
                                        • H
                                          line 103
                                          op=list[i+1]
                                          index out of range
                                          Do you recieve that message every time ? It didn't appear when I was using the Script.
                                          Shouldnt. 'op' is already the object with index 0, and 'i' starts with '0', so the next object for 'op' in the first iteration should be 1 => 'i+1'
                                          But .. Hm, very bizarre. I didn't recieve that error, but as I think about it, that error MUST occure at the end of the loop.
                                          Try it like this and tell me if the problen still exists:
                                          op = lst[i+1]
                                          if not op: break # Hopefully there is a 'break' expression for 'for'-loops. If not try something that stops the loop
                                          etc etc
                                          Why not writing a Plugin ? 😉
                                          cheers, nux
                                          • H
                                            On 27/02/2011 at 03:10, xxxxxxxx wrote:
                                            Using
                                            if i+1 < len(lst) :
                                            	op = lst[i+1]
                                            got rid of the index error
                                            As far as writing a plugin. A bit beyond me at present, probably best to learn from your foundation work here Nux.
