    Convert Object internally
    4 Posts 0 Posters 1.4k Views
      On 19/02/2011 at 20:06, xxxxxxxx wrote:
      Hi Guys,
      just started Python and I think I'm doing very well.
      I've created a simple Cloner with the Python Generator. Now I want to Convert the Clone internally to a PolygonObject.
      I tried SendModelingCommand() but it crashes because there is no document overloaded (because the Object is just virtual x) ).
      So, my Question would be: Is there a way to Convert an Object internally in Python ?
      Thanks in advance, nux
        On 25/02/2011 at 08:01, xxxxxxxx wrote:
        I could find a way to do it:
        def MakeEditable(op) :
          if (not op) | op.CheckType(c4d.Opolygon) | op.CheckType(c4d.Ospline) : return op
          op = [op.GetClone()]
          doc = c4d.documents.BaseDocument()
          doc.InsertObject(op[0],None,None)
          op = c4d.utils.SendModelingCommand(
                                    command = c4d.MCOMMAND_MAKEEDITABLE,
                                    list = op,
                                    doc = doc )
          return op[0]
        Cheers, nux
          On 25/02/2011 at 08:03, xxxxxxxx wrote:
          I recommend you to use c4d.Ospline, c4d.Opolygon,... instead of hardcoded constants. I would also use CheckType(...) instead of GetType() so it accepts subtypes as well.
          Cheers, Sebastian
            On 25/02/2011 at 08:29, xxxxxxxx wrote:
            Ah thanks, changed it 🙂
