    Camera Question
    2 Posts 0 Posters 189 Views
      On 14/02/2011 at 14:12, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Is it possible to have a camera that has a 360 degree panoramic projection?
      ~Shawn
        On 14/02/2011 at 15:55, xxxxxxxx wrote:
        That's not possible, AFAIK.
        What you want is an environment map for later renderings (such as an animation with the camera on a fixed position), right?
        What you can do (and it actually gives better results than a spherical map) is to create a cubemap. Render out an image with quadratic aspect ratio, camera FOV on 90°. One rendering for each of the 6 directions. A cubemap camera rig can easily be created with XPresso, or with an expression plugin tag.
        Map the resulting images on a giant cube surrounding the scene.
        And if you really need a spherical image, you might be able to convert the cubemap to a spherical map using polar coordinates.
