    Problem with GeUserArea
    5 Posts 0 Posters 498 Views
      On 08/02/2011 at 10:09, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      Hi Guys,
      I added a dialog to my OffsetRandomizer coffee-plugin and wanted to add a UserArea, so i can show an Image in the dialog.
      But i ran into some trouble, i can't actually figure out where the problem is.
      There is a banner.jpg in the 'res'-folder.
      const var PLUGIN_BANNER = "res/banner.jpg";
      LoadBitmap(path,resx,resy) {
        var fn = GeGetRootFilename();
        fn->RemoveLast();
        fn->AddLast(path);
        var bm = new(BaseBitmap, resx, resy);
        bm->Load(fn);
        return bm;
      class UserArea : GeUserArea {
      private:
        var bm;
        UserArea(id,dialog);
        Init();
        GetUserWidth();
        GetUserHeight();
        Draw(x1,y1,x2,y2);
      UserArea::UserArea(id,dialog) {
        super(id,dialog);
      UserArea::Init() {
        bm = LoadBitmap(PLUGIN_BANNER,1,1);
        Redraw();
      UserArea::GetUserWidth() {
        return 288;
      UserArea::GetUserHeight() {
        return 52;
      UserArea::Draw(x1,y1,x2,y2) {
        OffScreenOn();
        SetClippingRegion(x1,y1,x2,y2);
        DrawBitmap(bm, 0, 0, 288, 52, 0, 0, 288, 52, BMP_NORMAL);
      class OffsetRandomizerDialog : GeDialog {
      private:
        var banner;
        OffsetRandomizerDialog();
        CreateLayout();
        Init();
        Command(id,msg);
        CoreMessage(id,msg);
        RestoreLayout(secret);
      OffsetRandomizerDialog::OffsetRandomizerDialog() {
        banner = null;
        super(PLUGIN_ID);
      OffsetRandomizerDialog::CreateLayout() {
        LoadDialogResource(OR_DIALOG,LoadResource(),1);
        banner = new(UserArea, OR_UA, this);
        return true;
      OffsetRandomizerDialog::Init() {
        Enable(OR_UA,true);
        return true;
      The rest of the code should not be interesting for you, because it doesn't have to do anything with the Userarea.
      What I recive, is a black field that obtains previous used elements. Hard to explain, better show you.
      Watch Video here
      Any Idea why this is happening ?
      I also have a 2nd question. In ResEdit one can set an elements dimension. But it's obviously not in pixels. I sized my UserArea in ResEdit to 480x40, but on my screen it's just 288x52 pixels.
      Thanks in advance, nux
      //edit:
      Ah, and when i call the Draw(); funktion within the CreateLayout of the Dialog, the console tells me that bm is null.. ?!
      banner = new(UserArea,OR_UA,this);
      banner->Draw(0,0,480,50);
        On 10/02/2011 at 00:02, xxxxxxxx wrote:
        Ok, now I found the problem. I thought a new Bitmap with resolution 1x1  is loaded in original Size, but it isn't.
        new(BaseBitmap,1,1);
        My image has got a size of 288x52 pixels. Also, the size must be substrated with 1, because the Bitmap is an array of pixels, starting with 0. 😉
        new(BaseBitmap,287,51);
        Same in the UserArea in the overloaded functions 'GetUserWidth' and 'GetUserHeight'
                return 287;
              return 51;
        greets, nux
          It actually is.
          No, if the bitmap is 512x512 it will be initialized with 512x512. In any case it's not necessary. You can simply use:
            return 287;
            return 51;
          No, the real bitmap width and height must be returned.
          Please have a look at the following simple example of a dialog with a user area which draws a bitmap.
          var PLUGIN_ID = 910000;
          // definition of my user area
          class MyUserArea : GeUserArea
            private:
                var bmp;
                MyUserArea(id,dialog);
                Init();
                GetUserWidth();
                GetUserHeight();
                Draw(x1,y1,x2,y2);
          MyUserArea::MyUserArea(id,dialog)
            super(id,dialog);
            bmp = new(BaseBitmap, 1, 1);
            fn->RemoveLast();
            fn->AddLast("res");
            fn->AddLast("icon.tif");
            bmp->Load(fn);
            println(bmp->GetWidth());
            println(bmp->GetHeight());
          MyUserArea::Init()
          MyUserArea::GetUserWidth()
            return bmp->GetWidth();
          MyUserArea::GetUserHeight()
            return bmp->GetHeight();
          MyUserArea::Draw(x1,y1,x2,y2)
            OffScreenOn();
            DrawBitmap(bmp,x1,y1,x2,y2,x1,y1,x2,y2,BMP_NORMAL);
            ClearClippingRegion();
          // definition of my Dialog class
          class MyDialog : GeDialog
            private:
                var ua;
                MyDialog();
                CreateLayout();
                Init();
                Command(id,msg);
          MyDialog::MyDialog()
            super(PLUGIN_ID);
            ua=NULL;
          MyDialog::CreateLayout()
            SetTitle("Draw Bitmap");
            AddUserArea(5000,BFH_FIT|BFV_FIT,0,0);
            ua = new(MyUserArea,5000,this);
          MyDialog::Init()
          MyDialog::Command(id,msg)
          //    switch (id)
          class MyMenuPlugin : MenuPlugin
                MyMenuPlugin();
                GetID();
                GetName();
                GetHelp();
                Execute(doc);
                RestoreLayout(secret,subid);
          MyMenuPlugin::MyMenuPlugin()
            super();
          MyMenuPlugin::GetID()
            return PLUGIN_ID;
          MyMenuPlugin::GetName()
            return "Draw Bitmap";
          MyMenuPlugin::GetHelp()
            return "Shows drawing of user areas";
          var d;
          MyMenuPlugin::Execute(doc)
            d->Open(TRUE,-1,-1);
          MyMenuPlugin::RestoreLayout(secret,subid)
            if (!d) d = new(MyDialog);
            d->RestoreLayout(secret);
            d = new(MyDialog);
            Register(MyMenuPlugin);
            So i don't have to insert the Bitmaps size here ?
            So i was right. A friend told me this. I actually didnt try it again, since it works, with 'new(BaseBitmap,1,1);'
            Thanks for your correction!
            I could only think of theese reasons but I was not really sure. There was no example in the SDK, or am I blind ?
            It would be great if Maxon would add this one, I think that would have answered my questions and problems earlier.
            Cheers, nux
              Only as long as the user area and the bitmap have the same dimensions. The advantage of passing the Draw() area parameters to DrawBitmap is that only this partial area is redrawn. If you are not sure about it pass 0,0 to GetWidth()-1,GetHeigth()-1 to DrawBitmap.
