    Drawing a spline
    26 Posts 0 Posters 16.2k Views
      On 07/02/2011 at 13:59, xxxxxxxx wrote:
      Oh, thanks, couldn't imagine it's different in C++, but now i know better. 😉
        On 07/02/2011 at 14:05, xxxxxxxx wrote:
        Howdy,
        Yeah, coffee is very similar to c++, but from what I remember about coffee, there were more functions you had to call to perform an operation, where in c++ you simply performed the operation.
        Adios,
        Cactus Dan
          On 07/02/2011 at 16:04, xxxxxxxx wrote:
          hey scott would you mind sharing with me the final working code you got.  The4 code above keeps making my c4d crash out.
          Shawn
            On 07/02/2011 at 21:11, xxxxxxxx wrote:
            Sure. Here's the code again:
            SplineObject *sp = SplineObject::Alloc(3, SPLINETYPE_LINEAR); // create a linear spline with 3 verts
              if(!sp) return NULL;
              doc->InsertObject(sp, NULL, NULL, 0); // Add it to the OM
            Vector *gp = sp->GetPointW();// The point array of the spline
              gp[0] = Vector(10,0,-100);// Place the first point here
              gp[1] = Vector(0,0,0);// Place the first point here
              gp[2] = Vector(-10,0,100);// Place the first point here
              EventAdd();//Update all the changes
              sp->Message(MSG_UPDATE);
            I'm a little surprised that there's no code block formatting option for this forum. To make posting code snippets easier to read.
              On 07/02/2011 at 21:30, xxxxxxxx wrote:
              why not use [*code] [/*code](without * ) ?
                On 08/02/2011 at 01:08, xxxxxxxx wrote:
                There is, please check the BBCodes avaible for the forum:
                <[URL-REMOVED]>
                  I looked at the Circle.cpp example. But It's dealing with creating a spline primitive. Not a new spline from scratch. So I'm still not sure how to properly create a spline from scratch
                  I was refering to this part of the circle.cpp example. It shows how to set up a Bezier spline.
                  SplineObject *GenerateCircle(Real rad)
                    #define TANG 0.415
                    Real    sn,cs;
                    LONG    i,sub=4;
                    SplineObject *op = SplineObject::Alloc(sub*2,SPLINETYPE_BEZIER);
                    if (!op || !op->MakeVariableTag(Tsegment,2)) { blDelete(op); return NULL; }
                    op->GetDataInstance()->SetBool(SPLINEOBJECT_CLOSED,TRUE);
                    Vector  *padr = op->GetPointW();
                    Tangent *hadr = op->GetTangentW();
                    Segment *sadr = op->GetSegmentW();
                    if (sadr)
                        sadr[0].closed = TRUE;
                        sadr[0].cnt    = sub;
                        sadr[1].closed = TRUE;
                        sadr[1].cnt    = sub;
                    if (hadr && padr)
                        for (i=0; i<sub; i++)
                            SinCos(2.0*pi*i/Real(sub),sn,cs);
                            padr[i]    = Vector(cs*rad,sn*rad,0.0);
                            hadr[i].vl = Vector(sn*rad*TANG,-cs*rad*TANG,0.0);
                            hadr[i].vr = -hadr[i].vl;
                            padr[i+sub]    = Vector(cs*rad,sn*rad,0.0)*0.5;
                            hadr[i+sub].vl = Vector(sn*rad*TANG,-cs*rad*TANG,0.0)*0.5;
                            hadr[i+sub].vr = -hadr[i+sub].vl;
                    op->Message(MSG_UPDATE);
                    return op;
                  op- >Message(MSG_UPDATE) is needed to update the object.
                  EventAdd() is used to update managers like the Object manager. So only have to call it when you add new objects to the scene for example.
                    On 08/02/2011 at 03:25, xxxxxxxx wrote:
                    Thanks Matthias.. That helped a ton.   I've got it figured out now.  🙂
                      On 08/02/2011 at 08:13, xxxxxxxx wrote:
                      Thanks Matthias.
                      If it's something that you can easily do. Could you possibly add the code block icon to the top of the message creation window with the other icons?
                      If it's a hassle to enable it. Don't sweat it.
                        On 08/02/2011 at 09:41, xxxxxxxx wrote:
                        When I type in code examples I usually just type [*code] My Code [*/code] without the * as mentioned above.   🙂
