    Descriptionfiles for e.g. MoGraph ?
    5 Posts 0 Posters 429 Views
      On 06/02/2011 at 11:16, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi Guys,
      I am searching for the descriptionfiles for MoGraph, but i can't find them.
      I need the ID for the Renderinstances of the Clonerobject.
      Because C4D Versions older than 11.5 do not have renderinstances, i need to insert the ID manually too make my plugin usable for them too without having to distribute another version.
      cheers, nux
        On 06/02/2011 at 11:22, xxxxxxxx wrote:
        Omg, why not just print the variable for it ? Found a way 🙂
        But now another question.
        Why does it not work, when i declare a varibale with the specified ID for the Element and use it with PointNotation ?
        var RENDERINSTANCES = 1025;
        op#RENDERINSTANCES = 0;
        does not work. 😞
          On 07/02/2011 at 00:34, xxxxxxxx wrote:
          The ID for the Render Instances option of the Cloner is MGCLONER_VOLUMEINSTANCES.
          You can obtain description ID names by dragging them into the console or the COFFEE/Python script editor.
            On 07/02/2011 at 03:24, xxxxxxxx wrote:
            Haha, I know Matthias, thanks. 😉
            But I needed the *real* ID for this entry. As you can read here, I want my plugin working for Versions older than 11.5, too.
            Renderinstances are not enumerated in older C4D Versions, because it's not built in, so C4D tells me there was a variable or function expected (because it acrually doesnt know that variable). But in newer Versions I have to make sure that Renderinstances is not marked in the ClonerObject.
            I needed the real ID, which is 1025 in the ClonerObject.
            To get it, i just printed it into the Console:
            println(MGCLONER_VOLUMEINSTANCES);
            My 2.nd Question was, why it does *not* work, when i declare an own variable with that id.
            var INSTANCES = 1025;
            op#INSTANCES = 0;
            cheers, nux
              On 07/02/2011 at 05:21, xxxxxxxx wrote:
              You should always work with ID names whenever possible. ID numbers can change between versions.
              As for your second question, this is a limitation of the COFFEE # operator.
