    Decimal
    4 Posts 0 Posters 1.4k Views
      On 19/01/2011 at 16:42, xxxxxxxx wrote:
      does anyones know how to change the decimal precision of vector's number? I'm tryng to read a cloud of points from an external ascii document and is very important to have a least of 8 decimals.
      It seems to me that cinema 4d work always with 3 decimals. Is it possible to increase the accuracy?
      I've found this command "getcontext().prec = n" in a python documentation but doesn't work.
      Anyone got any ideas?
      Thank you.
      Luther
        On 20/01/2011 at 02:37, xxxxxxxx wrote:
        Hi, the numbers are just cut off for the user. Internally C4D uses double precision.
          On 20/01/2011 at 07:44, xxxxxxxx wrote:
          thank you for your answer. I had guessed as much! Is ti possible in python to unlock this limitation, for example when I print the coordinates of a vector?
            On 20/01/2011 at 14:16, xxxxxxxx wrote:
            Printing the coordinates of a vector should be fine from scratch:
            p=c4d.Vector(1.2345678)
            print p.x #output 1.2345678
