    GeUserArea - python
    2 Posts 0 Posters 867 Views
      On 16/01/2011 at 16:32, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:      Mac OSX  ;
      Language(s) :       PYTHON  ;
         Hi there,
      I am running into some problems with GeUserArea in Python. Hoping someone can help me with a quick example. I am trying to use a bitmap image in my dialog...
      Here is what I have so far:
      class DialogUserArea(c4d.gui.GeUserArea) :
          def GetMinSize(self) :
             self.width = 20
             self.height = 20
             return (self.width, self.height)
      def DrawMsg(self, x1, y1, x2, y2, msg) :
             startuppath = c4d.storage.GeGetStartupPath()
             path = os.path.join(startuppath, "plugins", "MyPlugin", "icon.tif")
             result, ismovie = bmp.InitWith(path)
             if result == c4d.IMAGERESULT_OK:
                 print("load ok!")
                 self.DrawBitmap(bmp, 0, 0, bmp.GetBw(), bmp.GetBh(), 0, 0, bmp.GetBw(), bmp.GetBh(), c4d.BMP_NORMALSCALED | c4d.BMP_ALLOWALPHA)
         def Redraw(self) :
                     print("load ok!")
      In my main dialog class, in CreateLayout()...
      self.AddUserArea(id, c4d.BFH_LEFT | c4d.BFV_CENTER, 20, 20)
      ua = DialogUserArea()
      self.AttachUserArea(ua, id)
      ua.LayoutChanged()
      ua.Redraw()
      This seems like it should be correct, except no image loads... I get a blank beveled area where the image should be and no errors in the console - only a print("load ok!") from my test...
        On 16/01/2011 at 17:37, xxxxxxxx wrote:
        Ok, I see the problem now (after much frustration)...
        My user area must be a distinct member of my dialog class, and then everything works like it should. Will try to post example code after I clean everything up.
