    Animation position/rotation using Python
    3 Posts 0 Posters 1.3k Views
      On 15/01/2011 at 14:27, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :       PYTHON  ;
      New to C4D but very experienced elsewhere. I'm trying to animate objects' position and rotation through the python API. I'll have to animate some other things eventually too. I tried using the typical approach of document.SetTime and SetAbsPos, but that didn't seem to have any effect. Is there a recording flag that needs to be turned on? Or are CTrack and CKey supposed to be used---but how? I see some forum posts relating to this involving DescIDs, where is the (meaningful) documentation for this? (in any programming language) Can switch to COFFEE if really necessary, but C++ is unacceptable for this application. Thanks.
        On 15/01/2011 at 20:28, xxxxxxxx wrote:
        Well,  I can show you the code I use to rotate my planet objects in PXG.   It is using C++ but it might help you with Python.
        //ROTATE PLANET
        Bool PlanetXObject::RotatePlanet(BaseObject *op, GeListNode* node){
          if (!op) return FALSE;
          BaseContainer *bc = ((BaseList2D* )node)->GetDataInstance();
          if (!bc) return FALSE;
          BaseDocument *doc = op->GetDocument();
          if(!doc) return FALSE;
          BaseTime time = doc->GetTime();
          Real fps = doc->GetFps();
          //Rotation Track Vector
          DescID idRotX = DescID(DescLevel(ID_BASEOBJECT_REL_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0));
          //Planet COUNTER CLOCKWISE Rotation
          if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
              bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_COUNTER_CLOCKWISE){
              //Remove Existing Track
              if (op->FindCTrack(idRotX)){
                  op->FindCTrack(idRotX)->Remove();
              //Insert the New Track
              CTrack *track = op->FindCTrack(idRotX);
              if (!track){
                  track = CTrack::Alloc(op,idRotX);
                  if (!track) return FALSE;
                  op->InsertTrackSorted(track);
              //Get the Base Time
              BaseTime bstime = time;
              //Set the Frame Rate (FPS)
              bstime.SetDenominator(fps);
              Real deNomin;
              deNomin = (60 *fps) / bc->GetReal(PLANETX_GENERAL_ROTATION_SPEED);
              //First Key will be set at 0
              bstime.SetNumerator(0);
              CKey *keyH = track->GetCurve()->AddKey(bstime,0);
              if (!keyH) return false;
              keyH->SetValue(track->GetCurve(),0); //Set Position to 0
              //Second Key will be placed at deNomin
              bstime.SetNumerator(deNomin);
              CKey *keyH2 = track->GetCurve()->AddKey(bstime,0);
              if (!keyH2) return false;
              keyH2->SetValue(track->GetCurve(),6.283185307); //Set Position to 360
              track->SetAfter(CLOOP_REPEAT);
          //Planet CLOCKWISE Rotation
          else if (bc->GetBool(PLANETX_GENERAL_ENABLE_ROTATION)  &&
                   bc->GetBool(PLANETX_GENERAL_ROTATION_DIRECTION) == PLANETX_GENERAL_ROTATION_CLOCKWISE)
              if (!track)
              //Get the Base Time
              Real deNomin;
              keyH->SetValue(track->GetCurve(),6.283185307); //Set Position to 360
              //Second Key will be placed at 3 times the location of the frame rate
              //(i.e. if FPS is set to 30, then the key will be placed at frame 45.
              keyH2->SetValue(track->GetCurve(),0); //Set Position to 0
          else
              //If the track exists remove it!
        Hope that helps you.  🙂
          On 20/01/2011 at 23:26, xxxxxxxx wrote:
          This will show you the very basics:
          obj = op.GetObject()
              t = doc.GetTime().Get()
              pos = c4d.Vector(0,t*100, 0)
              rot = c4d.Vector(0,t,0)
              obj.SetAbsPos(pos)
              obj.SetAbsRot(rot)
